ZROSSA
Everything posted by ZROSSA
Whats shocks to run with coilovers/camberplates
ZROSSA replied to a topic in Brakes, Wheels, Suspension and Chassis
You can also custom valve koni's any way you want them. There are quite a few custom shock builders out there. olin's , carrera , wp? are a few that come to mind. It wont be hard to find one of them that cam make something that will work for you. You will just need very deep pockets. They will need to know the weight of each end of the car and the sprung and unsprung weights, travel range and the spring rates. As was said before, thats a mighty stiff spring. I would guess that springs that stiff are for a car thats producing downforce. Thats something you will never have on the autocross track. I have never run on a autocross before but at a guess i think you would need something with great turn in and huge traction out of the corners. With sping rates that stiff you will have no traction any where! I would swap the springs for some below the 300 lb mark. You might be able to use a off the shelf shock then. Use the anti roll bars to control the car in the corners. Cheers Douglas -
Howdy all, I am making a new front nose cone for my s30. My car had a standard nose on it before so I dont have any heights to work to. Could some of you that have air dams/spoilers measure the distance from the ground to the bottom of the dam. I also nee a meassurement from the front lip to the radiator x-member. If you have any problems with scraping at the heights you run could you let me know as well. Thanks Guys, Douglas
Its a cool look. I couldnt find any, anywhere, so am making something similar for my race car. They would only be for looks on a road car. You could never run the thing close enough to the ground to make them work. I really dont think they are the right style for the s30. The clk mercedes one would probably look the best. Cheers Douglas
Pete, Your children will have left home by the time you have finished. Douglas
The front of the windsheild is always going to be a high pressure area. Cowl induction hoods use this to feed air in, not out. The best place for a air vent is further forward just behind the radiator. This is a low pressure area on the s30 and it will suck air out. Dave's suggestion of putting tell tails on the hood is a good one. Where they start to lift is where you want to put the vents. We have had some mighty fine discusions on this in the past, Might pay to do a search as well. Cheers Douglas
Is the bar new or used? If it came of a race car the bolt holes may have been stoled for more camber. You could do the same. Douglas
He is in aussie zline and talking in aussie $. Datto, Figure out how much power you want and work backwards. Dont forget the rb30 turbo that came in the c/dores. There are guys getting big power out off them and they are probably cheaper than any of the other options. I wouldnt bother with the rb20. If i was going to do a 2lt I would use a four as well. Probably a fj20. Cheep and mighty tunable. Douglas
Years ago I read a artical in a mag about a company on the U.K. that was making 3 and 4 rotor engines. They were based on the 12a. Interesting set up actually, he ran su carbs and was getting good power and not to bad fuel consumption as well. The mag was Fast fours and roteries. Probably about 7 years ago. I dont have them any more unfortunatly. Douglas
Thanks Jeff, I have deleted all the files and it seems to have worked. I know nothing about computers so this is all new to me. When I had problems in the past I just called network admin. Dont have that option now that I work for myself. Cheers Douglas
Not a time vortex. I will never get to pay day. It worked fine up untill that day. Bloody mystery to me. I will go and check my profile and see if any thing is different. Douglas
Howdy All, The last couple of weeks every time I log on all the dates in the forum are on the 14th of march. I have to go to the previous page posts and then back again to get the current ones. Also new posts are not marked unread. Any one else having problems of this sort? Cheeers Douglas
Other cars with same offset.
ZROSSA replied to DatsunBoy77's topic in Brakes, Wheels, Suspension and Chassis
Thanks again Mudge, A 265 tyre would work well for me. I could probably just roll the lips on the fenders and get away with it. Was the vette tyre a 45 profile? Douglas -
Thanks Mudge, Does any one else make 265/45/16's. You would be mighty pissed off if they stoped making them and you had gone to the expence of setting up for them. My 16x7's are multi piece so i might see if i cam get new rims to go on the centers and go up to 17 inch. There seems to be a lot more tyres to choose from in that size. Mabye something like 315/35/17's . Dreams are free. Douglas -
So what size tyre do you plan to use on the 16x9.5 rims? The largest tyre I can find locally is 245/45/16. I was thinking about having my 16 inch rims widened from 16x7 to 16x9 to fit the above tire. Can you guys get a wider tyre? Douglas -
I remeber reading somewhere that you can use marine grade carpet and underlay. Aparently its much lighter than normal carpet and the underlay is a excellent sound absorber. Douglas
Before I Cam to Hybrid Z i would have agreed with you Kevin. I have always been a fan of small engine that you could rev the hell out of. I am Not convinced that a 4 valve head is needed in engines larger then 5.0 lts. You just dont rev them Hard enough and if you do it costsa lot more $ to modify them to be able to live with it. 4 cams instead of 1 and so forth. The overhead valve engines seem to be much smaller and lighter as well. I guess what i am trying to say is that for a specific realistic power output its going to be much cheeper to get it from a pushrod engine. I noticed the other day that the Gen 4 chevy engine is still a push rod all be it a twin cam like the new harly engines. Douglas
has anyone ever done a buick 350 swap in a z series car b4?
ZROSSA replied to a topic in Other Engines
I get the feeling that your still looking for more info. I would love to be able to help but i have never set eyes on one. I was thinking about putting a v8 in a 911 at one time and I really liked the weigt of the buick so I did a little research. Mounts are not hard to do. Its just a case of measuring many times and cutting once. I am sure that the trans. mount can be done similar to the jtr one. Why dont you compare the buicks mounts to the chevy ones. That way you can work fom a base line that you already know the sizes off. You can also search the net. A lot of people replaced the buicks with chevy's becuase they are cheeper to get power from. Douglas -
Rear wheel drive is no problem. The boxer is north south mounted so you just dont hook up the front wheel drive shafts. I really don think it will fit in the engine bay. They are bloody wide. I will go and measure my wifes one...hang on....just under 30 inchs wide from valve cover to valve cover. It has a little over 30ml clearence between the heads on the frame rail. This car is a major pain in the arse to change plugs on as is. I am told the factory service manual says to drop the engine to do the plugs. It took me over four hours the first time i did it. Watch the import engines. Make sure you get the manual trans ones. The autos have less power to make the trans live. Tranmissions are the week link but they might get a easyer life in a rear wheel drive situation. The twin turbo are a sequential. One is larger then the other. The little one works a lower revs and the larger one kicks in about 4000 rpm. this is suposed to give a wider power band. Good in theory but in practise it doesnt really work that well. The factory STI cars make the same amount of power and use a single turbo. The sti cars are bloody quick. My father in law had one and untill he bought a evo 7 that was the fastest thing i had ever been in the odd factory V8 included. Look for a closed deck block. They came on the Legacy gt's and the sti wrx's. Another idea might be the engine from the Svx. 3.3 lts of turbo flat six seems like a better place to start. They all came in auto only though. This might just work after all. Douglas
FL327, I think Buick made two 350's. Big block and small block. The small block was developed from the BOP 215 ali engine. It should be pretty close to the chev in size and is 125 lbs lighter. In gs form from the factory it made 300 hp and lots of tourque. (long stroke) Not a bad donk IMHO . Douglas -
I think if i were starting over again i would have a good look at the ford windsor. Once it has ali heads its very light. I get the felling that its not as easy to get lots of H.P. out of them as the chevy. It might be wiser to base your final choice on a power figure you want and then work back to see what the costs will be. I am guessing that a 400 hp chev will be a lot less then a 400 hp ford. Another light weight engine is the buick 350. There was talk about the aftermarket making ali heads for these as well wich would bring it close to the fords weight with a extra 48 C.I. to play with. From what i have read these have excelent low end tourqe as well. Happy hunting. Douglas
ENOUGH STONY! Stop being a pain in the arse and tell us what you are up to . Douglas
I here you Denny but, .......When i was a kid my old man had a 1970 pontiac catilina wagon. You could get 3 in the front, 3 in the middle, 3 kids in the back. And if you were going for short trips you could get a couple of more kids in between the middle and back seats. If some one made something similar today I would have one. The whole concept of driving a truck when you dont need to is a bit odd to me. Btw my daily driver is a truck, however we are on a farm and it gets used like a truck should. Douglas
I was playing with the foam again this afternoon. I tried spliting the grill but it started to look a lot like the msa front cap, so off it came. Its coming along though. The opening is not quite oval and i have managed to incorperate the stock turning lights in now. The thing that i didnt really pay attention to before was that the z has quite a few sharp angles in its design. You cant just go and add something smooth to it and expect it to look right. Mabye this is what bugs me about about the g-nose. Any way the basic shape is done now. Its only in foam so i need to fill it and get it really smooth. I can take a couple of photos if any one wants to see it. I have no idea how to host them so I would have to mail them to someone. Cheers Douglas
250Z, Sorry I was a bit slack in getting back to you. I have been concreating and diging rocks up for the last week. Been sleeping very well. Guards red was the red for many years and is still a good one. Also have a look at the reds that the new comodores and falcons are coming out in. Very red, and they have plastic bumpers which might give you a indication of what it would look like on glass. There is probably only 3 colours I would use, Black ,red, or the blue use on the ecruse (sp) race cars out of scottland. They are all hard colours to live with. Reds fade. The blue and black will be hot as hell. I like reds myself. Cheers Douglas
