Z-Devil
  • Gender
    Male
  • Location
    So FL
Recent Profile Visitors
2904 profile views
Z-Devil's Achievements
Newbie
10
  1. Looking for Strut Mount Insulator for a 76 280z back passanger side.
  2. Gary, What class is Dustin running his v8 z in? Any finish time postings that you could link me to? I am very curious because of trying to learn the art and science of setting up a v8 z for autocrossing. Thanks, Jim
  3. As you have noticed it is a tight fit with the JTR conversion and full length headers.. If I recall correctly, they make metion of the fitting challenges. Anyway the Driver side Header had to be dimpled for the steering shaft to clear. The frame clearance is okay, although the control arm end is touching. Ground clearance for the collector sits about 1 inch below the frame rail. The header tubes drop about a half inch or so below that before raising back up at the collector location just past the firewall. Having had the Scarab conversion on another vehicle it was using the Hooker Super Comp full lenghth headers. I still have those headers in the garage. On the driver side, the first tube is removable.. maybe to fit around the steering shaft. They hang lower (too low) and will not fit in the JTR engine location as best I can recall. So on that vehicle after JTR setup I'm using the Hooker Super Comp block hugger headers. There is no clearance issue with them although they are shorty headers not full length. Those are small and close to the engine and the tubes collect in center and go straight down, but not far. You just have to make a 90 degree turn toward the back with the exhaust after the header. A buddy told me that the (short length) block hugger headers are fine until you are pushing 350+ HP, then you may be able to gain benifit from full length headers. I don't have any experience with the MSA v8 headers.. always kinda wondered about those also.
  4. Try S&S Headers for equal length tubes.. They make some especially for the Z cars.. http://www.ssheaders.com/muscle.htm look for DATSUN 240-260Z SB w/Front R&P 1 3/4" Sm.Blk./St. or Angle Plug 5205 It costs extra but if you are planning on keeping them for a while it is worth while to get them jet coated. They are the best for the money, that I know of at least.
  5. John, I'm interested in a front air dam.. will email you.
  6. Z-Devil
    Z-Devil 71 240z
  7. Z-Devil
    camber plate
    getting ready for coilover conversion
  8. Z-Devil
    280 pic
    my first z cars
