thanks for all the feed back it sounds like tune is very important and i just go my LC-1 in the mail so that will help me a lot
i'm thinking of running about 10 psi what kind of numbers were you guys making at this level
thanks
how much boost will a bone stock n42 out of a 75 280z take i'll be running a ok fmic, 92 octane, 440 injectors, ms. what kind of boost level can i run and what kind of power can i expect
thanks
tyler
can i build my ms1 v3 the standard way and install it like in the how to sticky and run the MSnS-Extra firmware so i get some of the extra stuff like the rev limiter or do i need to build the ms board different and wire it in to the car different
i found some konig wildcards for sale how do you think they would look on my 280z?
how would they fit i know i would need some of the Wheel Adaptors from Modern Motorsports but what size
thanks
witch ones
http://www.nolimitmotorsport.com/prod/ED686550
http://http://www.thezstore.com/page/TZS/CTGY/PBC08
are these long enough to go straight to the caliper
when ever i go to Modern Motorsports all i see is the kit is it possible to order just the lines
i'm doing the vented 4x4 caliper upgrade what Stainless Steel Brake Lines do i need to buy for it? where can i get them? will the ones they sell at msa work?
also can i go from the hard line on the frame rail straight to the caliper or do i need that little piece holding it to the strut?
thanks
well i was wondering because the na motor douse not have a oil cooler and the reason nassin added one to the turbo car was because of the added heat from the turbo. i was just wondering if the water cooled turbo would dissipate enough heat to get rid of the need for the oil cooler. i'm putting a turbo on an na motor and i already have a water cooled t3 so i just don't want to buy an oil cooler if i don't have to. also do i need the oil pump from a turbo motor or they the same?
thanks
i have a 77 280z i bought about a year ago and it's time for me to renew my tags. so i was looking at my engine and the previous owner put a header on blocked off the egr took off the cat and there is no O2 sensor. i put a cat on that i got from my friend and took it though the deq test it failed. what do you think i should do to get it to pass?
I'm currently collecting parts for a turbo swap and i was going to run megasquirt if i put ms on now could i get to pass?
I have a 77 280z and i was thinking about putting a zx turbo motor in it. but then i also realized that i need to renew tags soon. will the l28et pass the test in a 77? i live in Portland OR so there is no visual just a sniffer. also if i get a P.O. box somewhere where you don't have to pass emissions can i get around it like that or do i need an address to register it to?
thanks
how much do you think it is worth because he is asking me to make an offer. the body is ok but i just want it for the motor to put in my 77 280z
any input would be great
thanks
I found a '81 280zxt for sale but it has a blown head gasket is the motor a lost cause. What could cause the head gasket to blow? Would it be worth it to fix it?
thanks
