~KnuckleDuster~
Everything posted by ~KnuckleDuster~
  1. ~KnuckleDuster~
    IMG 9353
    From the album: New Parts
  2. ~KnuckleDuster~
    IMG 9352
  3. ~KnuckleDuster~
    IMG 9344
  4. ~KnuckleDuster~
    IMG 9337
  5. ~KnuckleDuster~
    IMG 9331
  6. ~KnuckleDuster~
    IMG 9389
    From the album: 73 240z
  7. ~KnuckleDuster~
    IMG 9388
  8. If and when, I do plan on running the plenum since I've got everything for it already and I can focus on getting that running right before I go all out crazy haha. The company that makes the manifold adapter plate says you won't be able to run VCT with it but there in the process of making an adapter to retain VCT. If I can keep VCT on the car I'll likely go for it. How did you get around this?
  9. Thanks I appreciate the input, I'll have to look into those guys as well. Glad to know there's a few options out there for obd1.
  10. I might have the wife get me this for my B-Day..Nissan consult adapter and some Data scan software. For around $150 it seems like a great tool to have. Then eventually I can go Nistune if I go with the ITB route so I can actually program the ECU to my liking.
  11. I should have made this a main focus a while ago. I wired up the check engine light and installed it in the bezel that used to house the glove box light, the hole was a perfect fit. I then wired the check connect from the consult plug with power wire to the switch in order to get the check engine code sequences and also be able to clear them. It's giving me 1-4 Speed Sensor and 1-1-1 Inhibitor Switch. The speed sensor is no big deal, who wants a 180kph limiter anyway? The inhibitor switch seem to be on the transmission somewhere and this I might want to address but not sure how I'm going to go about it yet, must research more. Glad to know everything on the motor is good to go!
  12. That was my concern as well. I took it out for a quick drive around the block and hit some sweepers. When I researched the solid steering coupler what I heard about them was the car will be to twitchy and you will feel more vibrations through the steering wheel. None of this was the case. Overall the steering just feels a little more responsive, in a good way. I didn't notice any extra vibrations through the wheel. Very pleased, more direct steering feel and I never have to replace it. Also on a side note the steering wheel was easier to turn lock to lock while sitting still, so maneuvering around parking lots and such will be easier. People who complained about the car being "twitchy" may have been running something close to stock tire width. I'm running a 235 so if anything I could use the extra quickness.
  13. Got a spare set of valve covers. Not sure if I'll stick with the black or go silver.. Going to try out the Techno Toy Tuning solid steering coupler. Steering should be sharper and Ill feel more of the road through the steering wheel, or that's what I've heard. I'll find out here in a few days.
  14. ~KnuckleDuster~
    IMG 9324
  15. ~KnuckleDuster~
    IMG 9323
  16. ~KnuckleDuster~
    IMG 9322
  17. Here's the gauges cruising around at night. I wish the info box wasn't as bright but overall quite pleased. Only issue I have is when I shut the car off the tach stays at whatever it was idling at rather than dropping to zero. I also finally re-wired the inspection light.
  18. ~KnuckleDuster~
    IMG 9316
  19. A lot of progress being made on ol girl. When doing the header swap I noticed cylinder 3 exhaust port was wet with gas. The intake manifold also had some gas blow by in it as well. So prior to me noticing this I was having issues with the ecu not keeping it's memory which I fixed by wiring the memory wire directly to 12v. This made a noticeable difference but I felt the car run faster than it was and I hadn't been able to track down the issue. I went through all the vac routing and sensors to make sure it was all in the proper places but that made things better but didn't bring that power back which I had felt only a hand full of times after the car was good and warmed up. So I assumed no spark was the culprit and installed a new coil pack on cylinder 3 and BAM, shes running on six cylinders now instead of 5! The car still felt good before but now holy crap can it rip around. The power is instant and pulls hard all the way to redline. So for the first time in 5 years everything's running perfectly and strong which is a milestone for this project. Exhaust note is better than ever too, my goal is next weekend for a video clip. I've been chipping away at getting the gauges all finished up and so far I've got everything installed and wired up with the exception of the tach signal which I'll be tackling in the next few days. I'm in love with the GPS speedo. The features it offers are really fun to play with. As far as the counter clockwise option..love it. It feels totally natural and just takes a quick glance to see how fast your going. Really unique feel to it and I'm super happy I took the chance on it. Here's the peak MPH recall feature. Your max mph hit for the drive will be displayed at the bottom and the needle points to the number as well. Did a 0-60 run and came up with a 6.2 not too shabby! I should be able to get that into high 5's with a flatter road and not at 2,000ft elevation.
  20. ~KnuckleDuster~
    IMG 9309
  21. ~KnuckleDuster~
    IMG 0915
  22. ~KnuckleDuster~
    IMG 0912
