MONZTER
    22
MONZTER last won the day on January 11
MONZTER had the most liked content!
About MONZTER
  • Birthday 12/30/1968
  • Gender
    Male
  • Location
    SoCal
Recent Profile Visitors
MONZTER's Achievements
Contributor
Contributor (5/14)
  • Reacting Well Rare
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Posting Machine Rare
Recent Badges
56
  1. Looks nice, Im guessing 260hp at 6500 to 7000k Do you plan on dyno testing it? Seems like it will be a super fun street car. Realy clean but not so over the top that you cant drive it everyday and enjoy it. Looking forward to more.
  2. Been a while since I posted any updates. Been moving along. For the Turbo car I decided to build my own wheels. Ill CNC machine the center sections myself and have the lips and barrels spun for me. I really like the old SSR RS8 wheels but finding them in the correct bolt pattern, offset, and caliper clearance is impossible. I fould a set close, from Japan and had them shipped over. Since this car uses Z31 hubs and such, the spacing is out much more than a standard Z so I need a bit more positive offset. I dissasembled the wheels and scanned the center section into my computer and reverse engineered the shape. Next I re-assembled them and had the 245-45-16 tires Im going to use mounted. I test fitted them to the car, and close, but not good enough. This is the fist time this chassis has been rolling on its own wheels in 27 years. Its been on a cart or a lift. Felt good to see some progress now that the suspension, brakes, and cross-memeber are finally complete Scanned this complete assembly and put it in CAD. Now I have the exact shape of the tire on the rim. Cool cross section of it. Finally I scanned the side of the car, put it into CAD. Now I can adjust my wheel center offset for caliper clearance, and adjust it to work with new Lips and Barrels I will order for the proper offset and fit to the car. Having it in CAD alowed me to look at it from every angle and check all clearances, for calipers, springs wheels lip, ect. Even compressing the suspension to make sure I have fender clearance at full travel Final wheel spec is: Rear - 5 lug = 245-45-16 on 8.5" width rim- 27mm positive offset, 2.25" outer lip on the rim Front - 5 lug = 245-45-16 on 8.5" width rim - 31mm positive offset 1.75" outer lip on the rim Next I need to find some time to program the CNC and start cutting chips. But I got distracted on the NA car, so that update is next.
  3. Yes, still working on then, just have not posted anything. Bought some expensive components that take time to recover from. A blank PAMS head, that I then designed and has DelWest make me titanium intake valves, Inconel mnemonic stainless steel exhaust valves, also MoldStar 90 seats and guides. Had it assembled, and ports cleaned up for some nice flow numbers. Also purchased a Nismo 6 Speed Trans that was also strengthened and modified by HPI in Japan. I take some progress pics soon.
  4. More pis of it finished up The bottom plate was beat up a bit and bent from floor jacks. So I took off the old one by drilling out the spot welds. I then drew up the shape and had a new one laser cut. The center plate that is welded to this plate, I re-made it as well, but out of 304 stainless steel. This way I can leave it a brushed stainless finish after powder coating and it is a good place to use a floor jack. I then spot welded on the larger plate in the original locations I then tigged the seam between the spot welds Then tigged on the center stainless plate Then blasted the entire cross member and powder coated it in a super black semi gloss powder coat. Powder coated the motor mounts as well I always first do a primer powder coat that is sandable I sand most off this off to fill the small blemeshes Then final coat Finally the brushed stainless plate for the floor jack Next up is getting a new transmission, then finishing the exhaust
  5. I finished up the front crossmember and motor mounts Started with a stock crossmember with the need for new engine mounting since I moved the engine in the chassis back about 1 inch. I extended and boxed in the existing upright Some grinding and blasting to clean it up 3 D printed mockup of a machined bracket I made to accept the moustache bar busings. I designed these years ago and have been in the NA car for 15 years. Worked well I machined this weld in bracket out of a solid chunk of steel because I wanted the details for the bolt holes and you could not do that with bent sheet metal. Stupid but fun. More soon
  6. Thanks, I enjoy keeping up with your projects as well, nice work you are doing on the intakes. I machined this plenum years ago. Made from 2 halves and welded together. Hoping to one day run it.
  7. No, scanner, I want one but not yet. Just did all the suspension and reverse engineering old school with calipers just measuring. It's all pretty simple stuff
  8. Here are some more pics Started with a backing plate from a Z32 Here is the CAD model where I got it all worked out for the proper spacing / fit, ect. Machined the parts from this CAD This is the first fit check. You can see how the rear hub bearing was modified for a 5 bolt Z31 turbo stub axle bearings and CV flange Just some final pics
  9. Hey Derek, you know my neighbor John at HyTech. Fun stuff. Someday a LY head if we could find the time?
  10. Ill Put some more pics of the diff mount/cradle and the trans mount. Yes, doing all my machining on a 3 axis using SolidCam. I buy the Aloding coating and the acid prep/wash from Aircraft Spruce. Its easy to do everything just has to be spotless clean and degreased. I designed and made this diff cradle so many years ago I had to dig up pics. Dont think anybody had something available back then This pic dates back to 2001, thats how long this project has been going. All the turned parts are done on a manual lathe and I did not have CNC back then so its all done on a manual mill as will. All 4130 steel, pretty light actually. Just a hobby so no hurry I guess Front diff mount is two OEM mounts cut in half and weled together, I integrated the solid mount into it as 1 pc. Here are some CAD pics of the mount. I actually have moved the engine back about 1 inch so I needed to make a new trans mount. Wanted something to go with the new design front motor mounts Ill show soon when I finish up the cross member. The bushings are from the outboard rear control arm urethane kit. I Its steel and aluminum contruction. I still need to put a finish on it. But I wont probably use it now as I am going to replace this S15 Trans with a Nismo 6 speed. So Ill have to modify the design and make some new parts. Front crossmember and Front suspension coming soon
  11. Duals, oops just a typo, duel exhaust pipes like original, thanks
  12. Back to work on the Z Turbo car and taking a break on the NA car after finishing up the body work. Time to dry fit the rear suspension for the Turbo Car. Designed and built my own control arms and rear support years and years ago, finally fitting it up. They are 4130 seamless Chromoly that I polished welded then clear powder coated. Here are the rear control arms. I stuck with the standard urethane mounting bushing fror the inner front pivot location, but used really nice Teflon lined Aurora rod ends everywhere else. I had some 6-4 titanium bar drops and plate, so I was feeling creative and made all the big control arm bolts from the titanium Here it is all installed with the brakes and custom parking brake cable as well as custom CV axles, Diff mount and front mount This is a custom front diff mount with a double hump for the duel exhaust that will fit in very nicely. The Diff is an R-200 with 3.70 gears and a Quaife Limited slip. Can remember where the diff cover was from, but I think it was a Nismo part. I bent up my own sway bars from StressProof steel and made two point adjustment links for the end. I machined some mounts with solid Teflon busings for the sway bars, similar tot he 280z placement, front mount style The bar is sitting too low and will hit the duel exhaust pipes so I need to remake the mounts and raise the bar higher in the chassis. Thats it for now, on to the front suspension and crossmenber next. Let me know if any questions, clarifications or more pics. Busy Summer.
  13. Last bit of body work was the hatch slam. I did not replace it entirely. After getting a Tabco replacement and then a classic fab replacement, I decided mine was not bad enough to justify changing the entire part out and reducing the originality as the replacement parts are not a 100% The original paint Drilling out the tack welds After drilling out the spot welds and cutting part of it away, I blasted the undelay of framing. There was some corrosion deepen than I liked so I cut it out and patched it. Then ground it back and sprayed it with a weld through primer Next I removed the rest of the panel, blasted it and replaced the little bit of rusted metal. Tig welded it and ground it flat along with some dolly work to make it flat after welding I then tig welded the old spot weld location and ground them flat so it looked like a new panel again. All the underserface of the rebuilt hatch slam got coated in weldthrough primer. I then applied a weld through seam sealer. I used the old pc of metal to mark the exact location of the original tack welds Final to tack weld it in. Looks great and factory original in my opinion
  14. Welcome back, I think you unfortunately find things have gotten quiet around here. Face book groups, scammers and short attention spans are the new norm. I came back here after a 10 year absence as I missed the old times too. Still lots of great info to be found, just not the level of new content we remember.
  15. Then on to the front fender, Inner and lower. Another KF Fab part fitted in and TIG welded Cleaned up the weld beads and spot welded it back to the lower fender return Same deal on the lower fender. lots of small tack welds to keep it fron warping and small welds. I kept the original lower flange of the fender so the fit would not change. It cleaned up nicely with some blasting, and will keep the original fit and look of the fender For TIG the metal needs to be perfectly clean forpretty welds, but the overlap of the inner fender made this difficult, but they will look fine when ground back. A grinder, a file and a shrinking disk got it straight. A skim coat of filler will probably be needed to make it perfect as I cant get behing the repair to dolly it out perfect. The Hatch slam is up next
