1QWIKZ
Everything posted by 1QWIKZ
  1. Great news Edan! Will be ordering my kit in the new year! Can't wait for track season!
  2. Still doesn't work. If you remove the "options" from the required information it should be good...
  3. Good to hear its ready to go! Unfortunately, I can't order the kit on your site without selecting the "no calliper/pad" option...and I need callipers and pads lol
  4. The issue you would run into is the clearance between the outer most face of the calliper coming into contact with the inside of the rim face. 2 ways to remedy this is to run wheel spacers (which move your wheels outward) or move the calipers in to maintain your stock rim offset.
  5. This is a common issue on early 2000 model year subaru WEX's with the newer 4pot fronts and 2pot rears. Running an OEM compound in the rear and a sport compound in the front seems to sort things out. Double check that everything is connected correctly first though...
  6. Also...you can't adjust rear camber or toe on the ZX. Both change with movement of the suspension...fault of the semi trailing arm design. As suspension compresses, negative camber increases and toe-in increases...
  7. I'll post video of it in action once it's on the car and lapping ...unfortunately, I'm in Canada so that will be next race season
  8. Sweet! What's your preferred method for payment and timing of payment?
  9. Thanks Edan, I have my stock 1983 280 turbo wheels sitting in the garage so I can test fit those if I get my kit early...
  10. We have 2 for sure so far and a third for january so we are getting close.... C'mon guys! Let's get this done!!! Edan: let me know...like I said, I can do without the plating to offset the "1 off" cost...Thanks for looking I to it for me. Rob.
  11. Hey Edan, Is it possible to have a kit shipped out before the list is full? I realize that you would prefer to order the brackets in bulk...but I wouldn't need mine zinc plated (which is where the bulk order is likely needed). I would just paint it with caliper paint. My Z doesn't see anything other than sunny days so rust isn't an issue. I would really like to get the car on the track this season so the sooner I have them the better for me!!
  12. I believe the kit includes: 11.2" drilled and slotted front rotors 4-pot calipers Adapter brackets Stainless steel brake flex lines All hardware Front brake pads This is a front kit only! Price $655 plus shipping (Edan: edit if I missed something!)
  13. Ok...I priced it thru FedEx and it was $73.83...so maybe I'm missing something. I'll call them Monday to double check... I want the kit for sure...and we can discuss shipping logistics thru email. Rob.
  14. $175? Really? I just did an estimate on fed-ex website (40lb package, 12"x12"x12" box, regular ground 3-5 bus days, from encino California to my home) and it was $58... What carrier and values were you using to get your estimate? I want the kit (we've been in contact about it since February)...but the shipping charge seems a little off... Rob.
  15. Cool! Hopefully I'll get a track day in this season with these!
  16. Ok! Thanks for the update! Just don't want this to fizzle out...or have people think it has...
  17. Cool! Just wanted to touch base and see how things were going...
