Joeoski
Everything posted by Joeoski
  1. Dang that bites , was it the package they put it in or did the mail person smash it up?
  2. Awesome Thanks for the link post this for more to see , Thanks Mike kZ .
  3. Cool so it seem this gasket will work out, Thanks for your info blue72.
  4. Any one uses this head gasket have good or bad things to say about it? here is a picture of the gasket/gaskets.
  5. got some 4 screw su's and the rear one's piston rubs on the wall of the dome and the scratch is small in side the dome from the bad movement and friction. any tips to make my rear Su carb move like a champ again . no net so i will see this later thank you for your info and help. and 100% its not the needle!
  6. I'm still on my carbs i took most the carbs a parts and put them in bags there not mixed up. I'm stuck once again how do you get the needle out if there stuck in the piston still ? use pliers ? i unscrewed the needles. The float bowl how do you unbolt it from the carb ? Then does any one have some pics on how the header and SU manifolds are put back on, like to put the washers and bolts back on , Any links will help me out of other peoples projects. Thanks.
  7. I'm going to take my headers and manifolds off my 240Z to put some new gaskets on and take off the cracked carb off , is there a order to loosing every thing? none of the book i have seem to have any thing on loosing order for header and manifold removal.
  8. Back again, OK first off people around me want to help with my carbs bad ideas they went and messed with screws C & D , Now My 72/240Z runs only with out the air filter off and only sputters with it on and everything around and in the car smells (Z's been sitting for 1½ months) help. Please give me some links for stuck flouts and needles so on , Thank you.
  9. I have the same problem with my 77 280Z , i thought it could have been the points in the dizzy. if you find it out let me know to .
  10. I'll look in to this later to. I checked the oil in the front carb to find it way below the lines just a little was on the brass end , If the Su carb float gets stuck would this make the oil run out quicker inside the carb ?
  11. i haven't seen any fuel leak out are soak in to any area of the carbs are the manifolds and the balance tubes ether , but where did your carb start to leak at ? thank you.
  12. 1972 240Z i don't know but if the Su carbs are not in sync will the gas work like a playstation 2 very little room to press the gas pedal tell im going fast and getting pulled over again i press the gas in about ½ inch and this car rockets through all the gears have to aways let off the gas when on the high way answers tips im great fully for any info thank you .
  13. I have been looking at those robs on ebay to. They have a weight control within 4 grams in a set if i remember right theres a set of rods out there within 2 grams in a set with the weight control around the same price.
