ndeli55
About ndeli55
  • Birthday 12/21/1983
  • Gender
    Not Telling
  • Location
    Edmond, OK
ndeli55's Achievements
Newbie
10
  1. Man this car is gorgeous. I am so glad you stayed with the Lime Yellow, it is my favorite z car color. Just love the way the light plays on it. Well done.
  2. Yes, it is on the firewall. thanks for the help. I just didn't know if that was likely cause, or if it was common. Thanks again.
  3. is it possible that the blockaged is actually in the proportioning valve? is that common? for as i stated before the flow is inhibited directly after this valve. if so where can i find a new one? or should i just put a t fitting on the front brakes and a proportioning valve on the rear brakes? any adverse reactions to this solution?
  4. ok i have a 73 240z, and it has been sitting for some time. i have recently tried to rework the brakes, rebuilding the two rear wheel cylinders and replacing the master cylinder with a reman. the problem i am having seems bizarre and after searching i havent found anything similiar to my symptoms. i pressurized the system using a power bleeder but found no flow at the wheel. when i opened the bleed valve at the calipers and wheel cylinders nothing. not even a spit. now if i open the master cylinder bleed lines i get plenty of flow. also i pulled the actual break line at the master cylinder and there was flow as well, now when i pulled the break line after the proportioning valve, nothing. is the proportioning valve the problem? or is something else at play? any help would be greatly appreciated.
  5. i still want to see an lt5 wedged between the bonnet of a 240z. but thats just me talking.
  6. mine are hinged on to the hatch, holes will have to be drilled.
  7. i have metal hatch louvers, if anyone is interested, i wont be using them id let them go for a good offer.
  8. looks to be missing a smog pump too. correct me if im wrong
  9. has anyone on this site ever heard of a air fuel ratio gauge that is screwed into the spark plug's threads, if i remember correctly its a british design, that i stumbled across a while back. i could of swore i bookmarked it but it looks as if i have lost it. i have been searching to no avail. any help would be greatly appreciated. ps. if i remember right it had a glass tube or some kind of chamber that changed from green to red or blue as the a/f mix changed.
  10. does anyone know if reaction research carries zg flairs as well? sorry for the hijack
  11. looks like you had tons of fun in the "apatchy" thats what im dubbing it. glad you could share
  12. ive been looking for some fg at a reasonable price, if you could do it i would most likely be in, depending on price. but customer care, like stated above would be worthy a sizeable tradeoff. a tilt forward front end would be awesome.
  13. never mind, just read the previous post about h2s
  14. if going down this road, why not get two kawasaki h2s, bond them together, they were an old 3 banger two stroke from the seventies. could get to around 1400cc inline 6 and it would be a two stroker and would sound wicked, and would have some major power potential, plus the blue smoke rolling out the back would be a blast. alternatively a couple of rz 500s would be cool, v4 2stroke water cooled engine. this would yeild a scary sounding 1000 cc z. hell while we are at it just get 3 banshee engines, put the 750 cc big bore kit on em and go to town. 2250 cc inline six mean machine. someone do it please.
