wickedminded
Everything posted by wickedminded
  1. Hello im daniel im really missing my zx a year ago a lady hit me pushing it up a business driveway tore door to fender bent the A pillar to the point it wasnt repairable and she paid the witness so if someone has a z or zx laying around preferably a roller near mesa az that can donate it to a person going through z withdrawals it would be greatly appreciated
  2. Well im in process of getting a 240z and my neighbor has an 1987 chevy camaro with the 305 tpi and was seeing if i could get some insight one thing im trying to see is if the 305s stock exhaust would clear the steering column but any insight would be greatly appreciated
  3. Alright ill search some more and I guess I have the right FSM but its just confusing
  4. Only shows where the other guy posted the pic I've searched all over my car lol
  5. In a hose? Where and person who posted picture I looked there on mine and its not there that's where the FSM said it was
  6. My valves are clacking too but I adjusted em cold by the FSM but I'm not familiar with this engine is it somewhat normal to hear small clacking?
  7. I have a 1982 datsun 280zx non turbo I'm trying to find the idle screw it says its on top of the throttle chamber but it isn't where it shows in the FSM so anybody know where its at
  8. Hello I have a 1982 datsun 280zx I'm going to be buying a spare engine to stroke out does anyone know where I could find the kit and at what price and how well would it work with fuel injection
  9. And my sixth injector started to squirt a bit and its on tight new o rings
  10. Plus another question what would cause my exhaust manifold to glow red?
  11. Its in about 65 percent I turned the screw to the left idle picked up turned it to the right and it slowed down and seemed like my injectors were pulsating faster
  12. No smoke just the blow through when I first got it running 2 months back its clear as day unless its cold
  13. Starts at 650 than jumps to 1000 than I was playing with the idle screw got the idle down a bit and than my sixth injector started leaking
  14. Its starts to idle at 650-700 and than a second later she's idling at 1000-1050
  15. I honestly have no clue this is my first car and the kid I got it from kinda did some messed up work dropping chain all of the above some how got timing 180 out just with a simple suppose to be change of head gasket I can do a compression test later
  16. I haven't removed anything I got the car from someone who said they changed the head gasket shaved it ect ect I had to put it back together my egr valve is there and connected
  17. Fixed the timing it was 180 out the distributor is set right ill check those things you mentioned and it shouldn't be idling at 1000 rpms right
  18. Lol okay its a 82 datsun 280zx non turbo stock L28 fuel injected
  19. I need help on how to properly set my fuel to air mixture it drives but it feels like its not driving how it should be feels like there is some restriction in accelerating which makes me think its running too lean on fuel but I don't know could you help me
  20. Its running like a champ had to get new fuel pump and got new water pump just cause I was there thanks for the help I've been learnng about my car time to try and see if it will smog
  21. Ok I have a couple more questions is your exhaust manifold suppose to glow bright orange and how do I adjust my air to fuel mixture
  22. One wire was fried from what I'm told the brown wire is known to burn everything works inside but the turn signals won't even turn on with the car on or off
