BOBBY BATES
Everything posted by BOBBY BATES
  1. Some may laugh at this but this is the way I look at it.Don't worry about the cost just save and buy as you can, if your worried about cost you don't need a z -car cause it is going to be like your next new kid to take care of..may take you longer to build but it will be right....If I had to guess what I've got in mine it would be almost $20k...thats $12-14k in engine and drivetrain,but I can jump in the car drive it around town and still run 9.00 @ 150 mph plus.....
  2. Nice looking Z Bobby!
  3. Ok here we go,doesn't have the LS1 in it anymore, it has a small block 434 with afr heads,10 to 1 pump gas street motor, 850 carb and bunch more.Still has stock half shafts and this are oem out of anther car i have for parts.:burnout:60' are around 1.45-1.50 the best has been a 1.39.?.?
  4. Still has the stock R-200 setup..just welded the gears up and let it eat!!!!!
  5. I have stock rear springs that I cut a round or two off and moved the mount up.For the tires they are M/T radial 255/60/15..Not bad for a pump gas street car...don't forget its FOR SALE!!!!
  6. Does anyone have the driveshaft adapter number for the v-8 swap..Has anyone found it any other place besides JTR ?
  7. Hey guys lose a u-joint this weekend at the drag strip,so know i've got to build a new driveshaft....the shaft i had came with the car and i always thought it my be too long,, Does anyone know how long there drive-shaft is???
  8. can you post a couple of shot of that grill? what year dodge grille did you use?
  9. Sorry for no pictures of the headers but i'll try and get them tomorrow.Its been a long 2 weeks swapping from a LS1 back to a old school sbc.But it was worth it!!!!! new best time,,well for the 1/8 that is...made about 6-7 passes and finnaly got a race...60'-1.29 1/8-5.6107 @ 124 mph...now next week we go for the 1/4 mile.......
  10. i'll get some pictures this weekend..on the passenger side where the lower control arm brace rod comes back ,i had to cut 1/8 to 1/4 of the treads off.
  11. The part number is 520-2243 in the Jegs book. They are in the frame headers and not fender well headers. Try are 1 3/4 and full lenght.My set up is not the jtr or scrab, its 50/50....With the jtr set up i think you would have more room...Best $550 i've spent.......
  12. I found that 62-67 chevy II headers will fit on the Z.Only had a little trouble on the pass. side......
  13. do you remember what year vett...1-5/8 could work but I think I'm going to need bigger..135 not to bad on spray.... mine went 153 on spray and when the tech guy got done with me you would have thought i had killed some one...my have to give you call next time i'm in san marcos...
  14. I know jtr makes a set but, has anybody found any better, bigger? I'm going to a 434 and I'm just looking, If I can't find any off to the race shop to get a set but hell thats high.......
  15. Have you looked at thunder racing, i'm running there alt. bracket..
  16. I am swapping from a R180 to R200. Could someone post a picture of the rear cross member and mustache bar. I need to know if the mustache bar goes in front or behind the rear cross member brackets. I am having clearance problems. Thanks
  17. Broke some parts this weekend at the drag-strip... I thought i had a r200 rearend in the car, but i don't..You show pistures of a later model rearend and you are call it a K r180...I think that is what i have because the inner stub shafts has a bolt in the center that holds them in ..I also have a aluminum cap that bolts on to the rear end where the shafts go in.But my rear end doesn't have a K casted in the top of it.My problem is i need a couple of inner stub shafts!!!!!!! can any one help?
  18. What headers are on that car??? do you think they would fit on a Z??
