Everything posted by Dat260Z
Aggressive fitment for zg-flares?
Dat260Z replied to Jimmy's topic in Brakes, Wheels, Suspension and Chassis
Hey jimmy , what size tires are you running on your RB's ? -
I paid $400 for an entire car 82 automatic with 116k miles .. Wasn't running but I'm doing a full build nothing really stock except the obvious , block /internals/ exhaust manifold and a few other items. Just look around I say not running but it ran on propane
- 18 replies
- 1
- l28et
- l28et price
(and 1 more)
Tagged with:
Is it really worth the trouble to use this cam? ?
Dat260Z replied to Dat260Z's topic in Nissan L6 Forum
I think that's what I'm going to do. What's the going rate for a C-stamped cam? It has a little corrosion on it but nothing major (I don't think) Thoughts? -
Thanks for the input guys..I don't plan on doing any headwork right off the bat so I've got some time to decide what exactly I want to do..that will also give me time to save some $. I will be running my SDS engine management, this build is not bare bones by any means so I don't mind spending the money for a custom grind cam and stiffer springs and other goodies. I've heard from a couple sources that it is good cam for turbo applications "if you can find one" and I just so happend to stumble across one for a old deal that's why I picked it up and here I am regretting it ..oh well :/ at least it was cheap :0 -
I recently picked up a 260z c-stamped "Nismo " camshaft. I am building a l28et and plan on bolting up my p90 head. As I read about swapping an early camshaft onto a later head i realize that I need to get a spray bar from an earlier head to lubricate the camshaft. And I can't help but wonder, is it really worth the trouble to use this cam? I can't seem to find any numbers as to how much this camshaft will benefit my turbo engine. Any help is greatly appreciated ! Thanks -Brad
I have a set of 16x8 +0 offset rota RB's in gunmetal gray on my z and I will soon be painting and adding flares. Therefore I need some wheels to fill them out. Looking to trade for some 16"-17" wheels 9"+ wide with a negative(-) offset. I haven't purchased flares yet so I'd be willing to go wider wheels and get some wide zg flares if the opportunity arises . Otherwise I'll stick with regular zg's . Willing to put cash/z parts on top for the right wheels. My wheels have no curb rash or damage. Looking for wheels in the same condition Thanks hybridz
I have a MS relay board and injector harness id be willing to let go if your interested. It has pigtails for Mitsubishi 390cc injectors , ka24 60mm throttle body converted and a few other sensors I believe ..I'll try to grab some photos this week
I am in the market for EMS , I already have a Megasquirt relay board and injector harness. Looking for an ecu that will run my EDIS COP , methanol injection, boost control , and have options for launch control. Figured I would put a feeler out before I drop the money on a new unit. , I would also need the tuning cable and other necessary items . Thanks
I have a bunch of misc parts ..a few stock l28et parts, s30 interior, 2+2 parts , what do you need?
Looking for a useable exhaust header for a square exhaust port. Not looking for exellent condition, just useable so I can drive my 260 to z nationals in October . I have items to trade, willing to trade double the value in parts for the header . Located in savannah,ga 31419 Thanks hybridz!
Zforceproductions makes a 3 gauge pod that mounts where the center air vents mount in the dash..I have seen an A pillar gauge pod around somewhere but I can't recall who sells it
I used a product called "peel n stick" bought from Home Depot for 16.99 a roll, used about 3-4 rolls for my 260z. I first applied POR-15 after scraping off the original sound deadening and then applied the peel n stick. Ill see if i can dig up some photos
I have a front bumper with a tad-o-rust ..$200 shipped I can email photos
Bump!
Still looking!
280z JSK rear brake setup question
Dat260Z replied to Dat260Z's topic in Brakes, Wheels, Suspension and Chassis
I ended up having to get a pair of spacers for the rear, wheel was hitting the caliper by about 2mm. Threw some 1/4" spacers on there until I can find some brake lines . I didn't realize that the calipers won't accept standard seated brake lines. -
My phone resubmitted my post. -
Jmortensen- what MC/booster/proportion valve did you run with your brake setup? I've got a 1" and an adjustable proportion valve on the way. Not sure if I should upgrade the booster as well. -
I am a professional painter with years of experience in multiple types of paint and paint sprayers. I wouldn't recommend wet sanding the basecoat. If you are using basecoat-clear coat I would make sure that your primed surface is completely clean of all imperfections (hard sand scratches/trash in primer/pinholes from filler ect... Use a tack cloth to clean settled dust right before you apply basecoat ( be sure that your basecoat is reduced properly or else it will not spray right) wait approx 10-20 mins between coats (2-4 coats should be enough unless its a transparent color) Once the basecoat is tacked off you can begin applying clearcoat ..first tack coat 25% overlap the following coats 50% overlap . But everyone has a different technique . If you have any questions shoot me a text phone call and ill be happy to help the best I can. 912-224-4731
Norman V- I am running the Techno Toy Tuning coilover setup. But the guy I bought it all from did not section the strut housings for the short stroke strut inserts. So that is next on the list -
I have 16x8 0 offset Rotas . They clear my z32 calipers up front Got it all mocked up, found some longer bolts for the bracket-hub, now off to find some bolts for bracket-caliper. And to dig up one of my missing stainless brake lines -
Should I just go to the hardware store and get some grade 8 bolts with lock nuts? -
I bought this rear brake setup from a guy on here, and this was what the kit came with, rotors/hats, caliper brackets, calipers, pads.. and no mounting directions..but the install looks pretty straightforward. My question is what should I use to mount the calipers to the brackets? There are no mounting bolts(that I know of) Any help is appreciated
What do you mean by Separation from the rear window? I did it for looks, If was looking for downforce I would go with a ducktail or something similar. I used a rear window spoiler from a 350z, I had to cut 5" out of the center and fiberglass the two halfs, it uses double sided tape to hold it to the glass. I just have it mocked up in the above photo. I can post more once I get it finished
