Dat260Z
Everything posted by Dat260Z
  1. Looking for a pair of fiberglass fenders for my 260z. I prefer no cracks or damage but I may be interested if there is minor damage if the price is right. I am looking for something close to savannah,ga /Atlanta.. close as in 4 hours or so Driving distance . I'd rather not pay $150+ for shipping. Thanks in advance!
  2. A have a relay board for sale..it's usable with any Megasquirt ecu
  3. I have one from an 82' it was shortened by an inch
  4. I have the doglegs and dome light panel you can have them for free. Just pay for postage The hard plastic backing is cracked on the lower part of the doglegs shouldn't be difficult to repair
  5. What kind of brakes are you looking for? May be interested in trading my rear setup..any photos,paperwork for the p90?
  6. Oh yeah thats tough.. I replaced mine..good luck
  7. I have some rota RB 16x8's if that sparks any interest
  8. I used an air hammer to get mine out..it's much easier with the control arm/strut assembly off of te car..soak it with PB blaster and hammer away
  9. I have everything off of an early 74' 260z not sure if they are the same
  10. Already found one, installed it and now about to pull off for turbo swap...thanks!
  11. Dat260Z
    Rota RB-R
    I have a set of the 16x8's . They fill out the fenders well on coilovers. 205/50/16 tires
  12. I know someone with some 280 strut casings..they are preferred for sectioning IIRC ..message me if interested
  13. I have an edis coil on plug bracket $50 megasquirt relay board with engine harness(poorly wired from PO) $75 stock l28et downpipe with OEM gasket. $30. coil/dist cap/wires (used) $30 for all.
  14. I have a set of 3screw SU carbs with intake, fuel pump, coil,dist cap, wires and everything needed , carbs were rebuilt this year with all components from zTherapy rebuild kits. Also have a 6-2-1 exhaust header for sale. Private Message if interested
  15. I have driver/passenger window regs from an early 74' 260z
  16. I have an uncut engine harness from an 82' turbo . Also stock downpipe,j-pipe ,oil pump(no shaft) . $140 shipped for it all
  17. Well dang..I suppose I will post it up for sale..any idea how much I should ask? I'd rather someone else get some use of it because ill prob end up going isky or something down the road when I get into head work.
  18. H4 lights.com has the housings needed. The HID kit comes with a relay harness. It's about $40 on ebay now ($60 when I did mine) for the bulbs/ballast and relay harness. Also comes with wiring diagram and directions to wire it up. I did mine in less than an hour (heatshrinked everything nicely ) I have the xenon slim ballast hid kit Just like this- http://m.ebay.com/itm/271315523739?cmd=VIDESC I have had them in for almost 2 years with no issues.
  19. I did an H4 conversion. H4lights.com. Pick up a set of Bosch glass housings for about $50 and a got a set of hi/LO HID's with a relay harness. Constant 12v only reusing one of your old headlight plugs for signal to relay box. Best upgrade ever for a little over $100 Video of hi and low beams below http://s30.photobucket.com/user/skimattybee/media/Mobile%20Uploads/IMG_0315_zps6a15b51f.mp4.html
  20. Hello fellow hybridzers! I am in the process of stripping my 260z for re-paint and l28et swap/engine bay tuck ..I am eliminating all of the old wiring that I can and I will no longer need this. I know it is pretty rare, should I hang onto it for the sake of it being a hard to find original part? Or is it even worth anything ? Thanks for any input Here is my z ..just because I want to show her off:)
