two40zjunky
About two40zjunky
  • Birthday 09/03/1976
  • Gender
    Not Telling
  • Location
    Lancaster, CA, US
two40zjunky's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
10
  1. Printing as I type this. You are awesome for sharing this with the group!! Ronnie
  2. Very cool read on your project. It looks awesome and fun as hell to drive.
  3. I ordered the parts from Jegs. It is much cooler than just having my low profile plenum hung over the header. I kept the tube 4" all the way to the stock air vent hole and stepped it down to 3" to go through the stock hole. I only had to modify one part of the purchased bits to make it fit perfectly ( perfect in my crazy mind ) in my bay. Thanks for checking it out. I'm changing a few things over the next few months.
  4. Picked up a new aluminum radiator with dual 12'' fans and a shroud. I also installed new wind shield wiper pump and all new hose. I installed the fans and they were loud as hell!! I actually wanted to pull them back off the car and reinstall the stock fan. after a quick inspection i realized that the fans were loud because one was loose on the fan motor and both fans vibrated on the shroud making it sound like an air conditioning system for a diesel truck. made a rubber gasket for each fan and slipped it between each fan and the shroud. it made everything pretty quiet under the hood. for the windshield water pump I used Anco PN# 61-13 and it fit into the stock rubber mount with minimal modification. Got the horns working and took some time to make them look good again. now I just need to install the LSD and start saving some cash for the motor that I am hiding from my wife.
  5. you should post some pics anyway. that might take some of the heartbreak away.....
  6. here she is on the ground with the wheels and a bit of a bath after a few years of chilling in the garage.
  7. I have a cage that I am waiting to install in the car. I'm trying to take care of a few other things first before I get my car to the welder.
  8. Those bars are pretty weak and usually cause more damage than it's worth if you wreck hard enough. Just get a roll bar from someone and you should be good to go.
  9. Made a heat shield from a piece of a 1941 Hawker Hurricane that was shot down. My buddy has the wing hung up in his living room and gifted me with a huge piece of this beast to use for something cool. I need to add the rivets and make clean up the edges just a bit.
  10. Nice to get back in this car after 3 years of sitting in the garage.
  11. This is an awesome project. Can't wait to see more progress on this build over the next few months.
  12. Finally got some rubber on the Rotiforms. Also finished up the intake so the filter is actually getting some cold air.
