Tim H
Everything posted by Tim H
If i use the ground wirewhich one should i use there are two grounds per coil pack?
I'm thinking i would use the 5volt trigger wires.
Will i use the 6 trigger wire or the 6 ground wires?
can I just run the diodes off the negative side of each one of my coil packs and then also run a diode coming from my tach wire? thanks for the help
Megasquirt 2 V3.57 L28ET
please tell me how to hook up the wiring to make my stock 280z tach work with the 6 LS coils
I'm sure this has been covered previously. Can someone please tell me how to get the tach wired correctly so it will work with 6 Ls2 coils? thanks Tim
just bought 2001 Kia Sportage front door rubber seals from Pick a part in ontario, ca. $6.33 each. they work AWSOME took less then :40 to install on my 1972 240Z VERYT HAPPY
Please help looking for warm-up enrichment settings MS II L28et
I got spark and timing is set at 10° while cranking the engine. But it won't start it trys to fire a couple of times. It seems very rich plugs are wet black smoke coming from exhaust pipe while cranking. What do I have set wrong.
Thanks. I think I figured it out I had the dip switches set wrong working good now.
I bought a MS II assembled from DIY coil driver installed by DIY. my problem is hooked up to JimStem board I can not get a consistent engine rpm. also the fuel pnmp light is not steady it flickers at the same rate as the injector banks. please help
L28ET T3T4 TURBO STAINLESS VALVES STAGE 2 SYNDER TURBO CAM ARP HARDWARE DUAL BOSH 44 FUEL PUMPS AROMOTIVE FPR NEW 3/8 SUPPLY AND RETURN FUEL LINE 3" manderl bent exhaust 2 1/2" manderl bent intercooler piping tial waste gate and blow of valve hoping for 350 to 400 rear wheel horse power I will be using the stock dizzy with Diy wheel to start. ready to buy megasquirt ecu just not sure which one is best and easiest to tune. I would like to control fuel, spark, fuel pumps, fans all with ecu. Please help if you have experience with megasquirt
Ok thanks thought someone might have done this already and could give me the answer.
L28ET with tial 50mm bov I'm trying to find out which spring to use. Or if anyone nows how much vacuum these motor pull ican figure out what lbs spring. thanks Tim
MS3 w/ MS3X Install - L6 turbo, sequential injection & boost control
Tim H replied to Sam280Z's topic in MegaSquirt
Ok thanks Sam are there any injectors you could recommend for a 350 to 400 horse power range? That you know from experience work good. thanks tim -
Sorry I've been working all week. Injectors, I have not bought yet thinking bosh 660 Any suggestions I would like to be around 350 to 400 hp -
Looking for ms advice L28et Ross forged flat top pistons stainless intake and exhaust valves schider stage 2 turbo cam and valve springs ARP head bolts, rod bolts, main bolts comectic head gasket t3t4 turbo tial waste gate, tial blow off valve turbonetics intercooler air to air DIY customer service told me I needed to choose bank or sequential. Is the sequential worth the money? what o2 set up do you recommend -
Looking for a weber or 240sx throttle body for l28et buil
WTB clean L28et valve cover
WTB L28et timing chain cover
Looking for after market barbed style fuel rail for l28et
Looking to buy a barbed style fuel rail with gauge. What is the easiest way to handle the transaction? Thanks Tim Profhomdel@aol.com
WTB N42 non ERG intake manifold
- 3 replies
- N42
- non erg intake
- (and 7 more)
