bacarl
About bacarl
  • Birthday 12/18/1983
  • Gender
    Male
  • Location
    Michigan
bacarl's Achievements
Newbie
  • Dedicated Rare
  • Week One Done
  • One Month Later
  • One Year In
Recent Badges
0
  1. Bringing back this excellent thread... Does the booster need to come off in order to remove the push rod assembly and check for the reaction disc? Even though blue72's was off the car, that doesn't seem like a necessary step from looking at the pics, correct? Granted, if the reaction disc is missing I suspect the booster has to come off to shake it out of there. Also does removing the push rod tend to tear up that seal? I searched MSA and googled the internets at large but didn't come up with a replacement. Are seals typically reusable after pulling them out of the booster?
  2. +1 NewZed, that's basically what happened to me. Not thrilled about the saggy-looking rear on my new Eibach set up. PseudoSport's car looks a lot more even front/rear. Assuming these are given in lb/in, then the front rate is 54% higher than stock (83 lb/in) and the rear rate is 60% higher than stock (103 lb/in) which is reasonable for a street car, and sounds like the rates were developed for the Zcar as opposed to being designed for some other vehicle and just happen to fit the S30. Also remember the "drop" amount varies based on aftermarket shock gas pressure which adds to the spring rate, etc etc. edit: John C or anyone, any idea if these springs have limited availability? I'll ask brandcarparts what their stock looks like but from some posts on this thread it doesn't sound like they're all that responsive.
  3. That sounds like a bad spring rate. Did you cut coils off, or by chance are you running a heavier power train? I've also read (at least of the Eibachs) that it can be easy to install the rear springs in the front and vice versa. Any chance that happened?
  4. Which Tokico shocks - HP or Illumina? What do you mean by "bound"?
  5. I know this thread is a few months old but I figured I'd bring it back because I'm struggling with the same questions as FrankieD. My stock springs are in good shape as far as I can tell without rate-checking them, but my car needs new shocks. My understanding is that suspension upgrades come in one of two flavors these days: 1) keep stock springs, in which case a modern gas-filled shock will contribute to a higher effective spring rate (wheel rate) and raise ride height 2) install a lowering spring, all of which seem pretty aggressive and may have other negative consequences (reduced jounce travel, excessive bump stop engagement, scraping hard parts, harsh ride) Are there any other options on the table? What spring did you end up with, Frankie?
