Everything posted by shadesh
.. still looking for someone to trade. not sure what happened with Henry. If you still have it call me.. Thanks.
Henry, I will call you. Thanks!
Hi, I have a set of wheels that are Enkei look alikes and would like to trade them for Snowflakes or other ZX wheels you may have... I am in Hawthorne, CA and prefer local exchange only. Thanks Shadesh
I have a functioning one from a 1975. Let me know.
Can an Arc Welder be used for my project?
shadesh replied to shadesh's topic in Fabrication / Welding
Everyone, Thanks for your input and yes I am still following this thread. I have not bought a welder yet but am considering saving and buying a name brand welder in the 300-500 range. Atleast I will be rest assured that I can utilize the welder for various welding needs. Grumpyvette made a comment about saving over a period of a couple of years before being able to buy one.. Thank You for that because I learned that I ought to be more patient... and so I will continue to save. Oh, by the way, if there is someone in Southern California who would be willing to lend me a hand with your welder, please let me know... I actually only have a few areas (small) that needs a new piece welded in.. -
You may want to take a look at how the Volkswagon Bugs "popout" windows are set up..I have a 66 with popouts. There is a hinge on the pillar that has I think 8 small screws that go through the aluminum trim.. There other side has a latch that pivots open and shut... You could definately use that system for your z.. hope that helps.
I guess you fellas are right.. I might as well save up and get something like Roostmonkey suggested... man!.. Well Thank You all. again.. I appreciate it. -
Thanks for your input. I appreciate it.. -
Will something like below work? CHICAGO 90 Amp Flux Wire Welder, MIG 100 .BRAND NEW . No Gas Required . Specifically designed to use self-shielding flux-cored welding wire, eliminating any need for gas and regulators normal MIG welders require. Includes: 4" spool of flux-core wire, spare welding tip, wire brush/hammer and welding mask Self-regulating feed control Thermal protection with warning light Carry handle on lid Input: 115 volt, 15 amp, single phase Welding current (2 settings) 63 to 68 amps (low), 79 to 90 amps (high) Duty cycle: 10% @ 80 amps, 18% @ 60 amps Wire capacity: 0.030" -
I saw this welder for sale but was not sure if I can use this to do light welding on my datsun 280z? I have to weld some sheet metal (4 inch x 4 inch) and repair the rear hatch sill area. Below is the welder description. Should I buy? I know most will say to get a Mig but this one is cheap abd if it can be used for my purposes, I would like to go for it.. Weldmatic 100 - (115 v.a.c/60Hz) Arc welder - Uses stick electrodes - welds up to 100 amps Thanks all..
I thought about this and yes it makes sense to not torque at 25 ft lbs. I saw the chart you mentioned and yes, it states 13-15 I believe. However, I would like to direct your attention to page 94 in that book. It specifically states 25-33 ft lbs. I looked at my torque wrench again and I did dial it in at 25 ft lbs for the first round of tightening. Did I misunderstand something?
Thank You Sir..
I actually marked the cam towers before removing. and yes, I checked for binding while I was torquing the cam bolts down. I screwed up when i set the dial on the torque wrench... a really foolish mistake. I should have double checked to see I set it at the right # of pounds. Let this be a lesson for all that follow. Double check your torque wrench and also get familiar with how the numbers are marked on your torque wrench..
I think I have done it this time. I am rebuilding my cylinder head (N42). I was in the process of torquing down the cam bolts with my torque wrench. The manual says 25-33 foot lbs. This is my first rebuild and I totally miscalculated and set the torque wrench at 38lbs. I ended up stripping the thread in the cylinder head for two of the cam bolts. Is the head usable? What can I do to remedy this problem?. Can this be fixed? I am about ready to kick myself for such a foolish mistake. Any help on this will be appreciated. Thanks. Shadesh
Thanks Phlebmaster.. I will take some pics soon and post. Can anyone else chime in as well.. just so that we are certain...Please. Thanks.
I have a L24 engine and wanted to know if I can install the flywheel and clutch from a L28 engine? I bought the l24 without the flywheel and just not sure if I can swap... Any feedback will be really appreciated. Thanks. Shadesh
still lookin.. anyone. I was told that the 72-74 driveshaft will also fit the 81-83 diff..
