okamis30z
Everything posted by okamis30z
  1. well i might be getting my motor rebuilt soon anyways but thanks for all the advise now i need to find a good place to get my motor rebuilt lol
  2. no luck my gas tank just bent
  3. I was at that point lol but then I was actually thinking gas plus fire = no more 280z
  4. i finally got my 1976 280z to start again so i know it was a dumb choice to start then drain my gas tank i think but anyways i tried to drain my gas tank but the i cant unscrew the plug on the bottom its stuck i tried spraying wd40 rust specialty i think its called but it still wont budge then i tried using a cheater pole but nothing any suggestions? and the gas tanks straps are the same thing
  5. You put where I had the positive to the negative ?
  6. so switch the one that I have the plus on to the negative
  7. And it ran good before I messed up my spark plug port and left it sitting a couple months
  8. It turns over but just doesn't start anymore and it only turns over a couple times then it just clicks like when u have a dead battery. And I leave the battery. To charge but it stays on 12v
  9. I got a new fuel pump and I hooked it up and it doesn't work so I tried to just run a wire from the fuel pump to the battery so I hooked up to the fuel pump and the the positive on the battery and it works but only that way. any suggestions
  10. I've had my 280z for about 7 months now and it was running strong until one day I was changing the spark plugs and I stripped the port so long story short I just brairly fixed the thread on the spark plug port and got the spark plug in and hooked up the battery and the gauge only read 12 volts so I hooked up the jumper cables to see if it will move but nothing and now the car just doesn't want to start any help btw 1976 280z stock l28
  11. okamis30z
    okami z
    Pictures of my 280z and it's problems
