Hey guys! I've looked everywhere before posting this and haven't found anything like the problems I'm having here or on a few other sites.
I bought a pretty much stock 1978 280Z a couple months back as a project car and have constantly had these issues and have never been able to find the culprit. Basically when I try to let it idle it will drop to 500 RPM sit there for a few seconds then die, but if I keep on the throttle it will stay alive and run pretty good going through the rev range although at anywhere between 3,000-4,000 when you let off it backfires.
Now my other issue is when driving it will suddenly lose power and it will either come back after a bit or the RPM will start bouncing and it will just sputter and die, then after a few minute it will start right up and run strong for a bit. Or when starting out there is barely any acceleration until around 3,000 then it will pick up and pull hard. Although recently it just has barely any acceleration whatsoever. it's just dead no matter where in the rev range or which gear.
Almost always when this happens there's a popping that sounds like backfiring but is actually the AFM which gets stuck at say half open when it should be all the way then it pops and goes back to normal and power will return for a bit after that.
My personal thoughts are the AFM is bad seeing as how the car sat out and the AFM didn't have that plastic cover on it. Although the wiring could be part of the problem seeing as how all the fuel injector and sensor connectors are pretty much falling apart from dry rot.
What do you guys think it could be?
Thanks in advance!
