Everything posted by joey.youssef
I tried Poll Level and cranking and still no signal.
I think I had a setting wrong in Tunerstudio. I had Second Trigger Active On set to Rising but reading the manual again, it should be set to Poll Level. I will make this change and try it again. I just need to get my flywheel back to try cranking it, might be a couple days. Do you think that will solve my problem of no cam signal?
I followed the manual on how to set the position of the cam sensor. The attached picture is the manual next to what my cam sensor location is at. Only difference is my crank sensor is on tooth #6 from the missing tooth when engine is TDC.
Hello, I have installed the Jeep 4.0 I6 Cam Sensor. However, I am not getting a CAM signal on the composite logger. I did verify I was getting 5V, ground and signal to the switch. Jeep 4.0 I6 cam sensor I believe is an open collector hall. So I did jump JP7 on the MS3X board. R32 I turned it anti-clockwise many turns to ensure its all the way. R11 I used the ZC Testpoint, I got 2.41 V by turning it clockwise until it wouldn't go up any higher. I have the tunerstudio set to Toothed wheel, Coil on Plug, MS3X Cam In, Dual wheel with missing tooth. But still no cam signal on the composite logger. I'm going to move forward with starting the engine and breaking it in on the dyno using wasted spark. But I would like to get this sorted out... for others that are running sequential using the Jeep sensor and MS3X... can you please let me know what I may be missing.
Hello everyone, I'm getting ready to start my engine for the first time in the next few weeks hopefully. This is an L28 build using MS3X and I would really appreciate any base tunes or configuration files from those with similar setups so I can have a good starting point. Here's a summary of my engine: L28 using forged pistons, P79 professionally ported head, 10.2:1 compression Isky L6 grind, .540 lift & 270 duration ITBs with TPS and utilizing large balance tube GM MAP and Ford IACV connected to balance tube Crank Trigger and Jeep CAS GM-style coolant temp & oil temp GM-style IAT Electric fans using PWM controller 32 lb/hr bosch injectors GM LS COP If you've got a similar set-up (ITB, MS3X etc...), I'd appreciate if you can send me your .msq file and a recent datalog if available to get a sense of timing, VE, AFR and idle control settings. Thanks in advance! I'll be happy to share what I come up with once it's dialed in. I have also posted this request on FB Church of L Series.
Very generous of you Leon.... I'll let you know.
Trying to figure out if I should go 2.5" or 3" for my build. I have lots of mixed opinions, some saying 2.5" is more than plenty and others say 3" is the way to go. Has anyone with a higher compression (10:1 or greater), N/A & hot cam set-up have done a dyno comparison of a 2.5" set-up and a 3" set-up and seen any difference?
I am looking for lash pads. Preferably 0.230" thick. I am preparing to put together my motor. I am not sure the thickness needed for my build. I want to order thicker to machine to suit. TheZstore only has 0.175" right now. Anyone have a set or know where to buy thicker lash pads? Thanks.
I've seen Bryan Blake's graphs before. One thing I found interesting is that most people say that there is no point of going over .460" lift without having a professional port job because the heads don't flow anymore at the higher lifts. But looking at Blake's graphs, the P90 stock head still flows a lot past .450" all the way up to .550" lift. I was hoping more people can show there stock flow numbers before porting to compare.
Looking for some head flow information. Hoping I can get some people to post the STOCK flow numbers they had before porting for intake & exhaust. I am specifically looking for Intake (P90 or P79) and for Exhaust (P79 or N47). I know there is not much to do on the exhaust for those two head types other than blending the short side radius and some people remove some of the valve guides. Any information would be much appreciated. Thanks, jy.s30z
Looking for help. I am going to start putting together a motor soon and I have all the fasteners mixed together due to sitting in storage for a while. I also have access to bolts at my work if I am missing anything. I am hoping that someone has a list of what fasteners go where. Did anyone purchase the Bolt Kit from Zcardepot and has pictures of the stock list or something? Any help would be much appreciated.
Hey Mark, Do you do the standard light covers? If not, any plans to?
Do you have the flow numbers of your ported head?
Sorry - not selling, Found one for myself and the guy told me to make an offer and I wasn't sure what is considered a good price.
Looking for what a used R200 3.9 LSD goes for these days?
Looking for used or new Fidanza Flywheel for my 280Z. Part#143281
Looking for L-Series Connecting Rods from L24 or L16. These rods are 133.0 mm (5.24") LG.
No I haven't.... I just received my parts back from the machine shop and waiting on a few more items before I start assembly and taking measurements. Iv'e just been doing calculations on what to expect and something not making sense. Just wondering how/why the books are so off from real life. 0.020" is a lot to deck a block and everyone seems to be in this area and I don't think everyone has a decked block.
This post is to find out if anyone knows why the L28 motors have negative deck height when running flat tops (piston sticks out of block). From reading different people's post I see that the deck height measurements are roughly 0.017"-0.025". I never understood why when looking at the measurements from "How to Rebuild Your Nissan & Datsun OHC Engine" L28 specs: Block Deck Height = 207.85 mm Connecting Rod = 130.2 mm Piston Pin Height = 38.1 mm Crankshaft Stroke = 79.0 mm This should give a positive deck height of 207.85 - (130.2+38.1+(79/2)) = 0.05 mm (.002") I was just wondering if anyone knows why in real life we get a negative deck of ~0.5 mm (.020")? Which of the above numbers is not accurate to real life? Am I missing something.
Hello, Can one of the admins change my username to jy.s30z if it's not to much trouble. Thanks in advance!
In need of a turbo distributor for megasquirt conversion on my 78' 280z.
Hello, I have 1978 280z... The head is cracked so I am replacing it with a P79 head. I am wondering if someone has experience putting a P79 head on a N42 block. Does everything line up properly? I am buying a complete gasket set for my 78' 280z but do I have to buy the head gasket for an 81' 280zx to match the P79 head or would they be the same? My build is going to consist of the following: N42 Block rebored New Flat top pistons Grind camshaft if needed with new bearings P79 Head resurfaced (0.010") with complete valve job Remachined stock cam 245-270 degree with lift .460" Headers/Exhaust K&N Cone
I also don't want to have to run super premium fuel since this is a daily driver in the summer..... What is a good compression ratio to try to achieve when I am milling the head deck and boring out the block if I go with this P79 head flat piston block set-up?
Need some help on what I should do to my 1978 280z. I had to change the head gasket due to coolant leaking into the combustion.... When I sent the head to the machine shop for resurfacing they found that it was cracked near the exhaust valve on cylinder 3... I read that this is common with the N47 heads. I am looking for a replacement head and I found a P79. I was considering buying the P79 head and resurface it along with a valve job. Then I plan on getting new flat top pistons (0.020"-0.040" oversized) and replace the dished pistons I have in my current N42 Block and obviously I will have to bore out the block.. I currently have 2.5" exhaust, headers, K&N intake. Is this the correct step I should take or should I look for N47 or N42 head instead? I plan on using the stock cam. Thanks in Advance
