rookie z
Everything posted by rookie z
  1. i have a complete engine & trans .if you want give me a call 205-368-4563
  2. rookie z
    Wanted L28 N/A
    i dont know how far you want to drive ,but i have engine & trans .cylinder head re-worked 600 miles ago. give me a call 205-368-4563 ,ask for mike.
  3. he will get it but it wont be from someone buying that car .he has to sale what ever he is smoking!!!!!
  4. thanks everyone! it was the driveshaft hitting the sway bar.
  5. which ,the ones on the axles or the drive shaft. the ones in the shaft are new,i know thats not saying much.
  6. thanks , i will check that .never thought about that but i will let you know.
  7. i changed the oil and its still making the noise.i used my electronic scope & it sounds more like the axles,not sure 1st time with a z.
  8. thanks , i will try that and let you know.
  9. just looking ,every thing seems to be ok .the car had been sitting about 10 years when i got it.
  10. its coming from the diff. im sorry ,i thought i said that.
  11. i have a 78 280z ,i just finished with ls1 swap .i thought everything was good until i backed out of my shop .i have a clicking or popping noise when backing up but no noise when going forward ,anyone have this problem.
  12. i just wanted to thank everyone for helping me with my z.i am finished as far as for getting it running , now i can move on to the bodywork.thanks again!
  13. i put the resistor in and it started charging , but by the time i went to check the voltage it stopped charging.i tried it 3 diffrent wires with the same results ,so do you guys think i should replace the alternator or rebuild it or what next?
  14. should it be 12 volts?how about i splice a 12 volt wire into the connector .will that work?
  15. i dont have power the connector.should i have power there or what?
  16. i have the wire from the back of alt going to the + side of the battery but i dont have power going to the 1 wire connector on top of the alt.
  17. i have a 98 ls1 i my 78280z .i am using the factory wiring harness.there is only 1 wire going to the connector on the alt,i cant get it to charge.what am i missing?
  18. the pics were what i needed .i forgot about the connectors in the car .i had them taped up and tucked out of way.
  19. what connectors are those ? if that is for the coil ,mine are a diffrent color wires and all.
  20. i have 12.5 volts and fuel but no power at the coils or at the injectors.the motor is turning over and i have checked the grounds and all of the sensors and i even added a ground strap .how do i get power to the ecm?i 'm sorry , no power to the pink wires and they are not hot when cranking.
  21. i checked everything you said ,i even added a ground,still no spark
  22. i know the crank sensor is plugged but where is the cam sensor. no spark at all , i dont have a scan tool
  23. no fire to ls1 coils .i am using the factory gm harness and the ecu has been flashed. someone help
