jdmjunkies.ch
    7
Everything posted by jdmjunkies.ch
  1. Since i got the Zinc plated parts back i'm trying to push the assembly of parts. Just because it's so much fun to finally see the puzzle-pieces come together to bigger pieces Started with the installation of the lately returned Zinc plated bolt and lock-nut: Then felt like it makes sense to clean a lot of small bits before putting it together. I mean wile i'm at it.. Dentist tools... And and old toothbrush came in handy and worked fine: The result. Well i even cleaned them another 30minutes more after this picture: Then started with the installation of the rest of the parts. like the steering boot clamp / Dust ring and the tierod-link stop nut: So next step will be the installation of the NAMS / Nagisa Auto Motor sports (Japan) adjustable Tierod endlinks (now discontinued ) and the steering rack boots. Takes a lot of time to figure out how all belongs together and to clean all the small bits. but honestly it's so much fun
  2. Today i have some nice news: Got back my first load of parts from the Zinc plating and yellow-passivating (which makes it look "golden" and also secures it better from corroding: Honestly this was my first attemt ever in doing something like this. so not all parts ended up perfect as i hoped, but however most of them are usable and some of them were for trying anyway only because anything up t 39 kilograms was the same price so i put whatever part i wanted to have replated into the box anyway. Here's a closer look at the colour: So while i was looking at all the nice parts i got a bit motivated and decided to complete at least the fuel cap So i started with cleaning the still nice and soft rubber seal and adding a bit of Vasiline (Petroleum lube / Jelly) Just to make it last a bit longer. After done i put it back to the cap And installed all back together. Yay - first part complete But not only me was productive today, also Yves over at MUC is working hard at the moment and welded back some hand-crafted rocker panels: Still needs a few touches but it looks brilliant compared to what it looked before Here's another view: With the zinc-plating delivery today i got a lot of parts back which i was waiting for to complete the steering rack assembly and the Front subframe parts. So Expect to see a lot of these parts assembled soon
  3. Thanks mate. Lol, me too. Have planned buy a lot more rare JDM parts in future but currently i'm concentrating on getting the chassis done. so that will have to wait by now
  4. Thanks to a steel tube, a Hammer and the Torch i somehow managed to remove the steering column bearings which are only press fit. However it seems like i damaged the Plastic spacer and i'm still not sure how to remove the bearing on the lower part of the steering column Jacket. And on we go with the updates from the bodyshop. Yves at MUC is currently replacing the Floorpans, seat mounts, and rocker panels and installing the NOS Framerails: Thats it for now. More to come soon.
  5. Time for another update: 1) While still waiting for the parts to return from the zinc-plating shop i ordered and got some fasteners and small OEM Bits from nissan for the Pedal box. nothing spectacular: 2) Also my Bodyshop guy constantly keeps sending my updates andi hope i can visit him once again next week. Hower his work looks very promising and his fabrikation skills are stunning: During work (Area below the battery tray): The finished, hand-crafted product. Absolutely great in my opinion! Today he started with the floorpans and rocker-panels: Current state of the car. Not much original Metal left. but the work is just brilliant! 3) While waiting for parts and work i decided to disassemble the Steering column. Before: Almost finished. If someone can tell me how the bearings are mounted into the housing and how i can remove them, this would be very helpful. Will get the housings sandblasted and powdercoated and don't think the bearings like to have sand and heat inside. also the service manual, haynes and other books only mention "replace bearings if worn" but not how to... Any advice i'm very thankful for Hope the zinc-plating parts will return early next week and another delivery goes to the powdercoating company
  6. So here we go. Started preparing stuff for getting it zinc-plated / Replated. The company that does the work told me they can only remove slight surface rust and old zinc so i had to remove the thicker rust spots and old paint, grease and rubber: Started like this: 60 pieces total (Note the Snow in my Garden ) Gave all the pieces a treatment with paint-stripper. just to make sure everything is gone: After letting it soak for a while and then cleaning it with water. it looked like this - much better already Spent another hour or so cleaning all the bits with a dremel and a mini wire-wheel. Much better. Now ill ship it to the zinc-plating company and hope to get the bits back soon
  7. Honestly i would like to show you some assembly progress here but unfortunately im still in need to get all the small bits and fasteners cleaned and zinc-plated before i can continue. Also I have a bunch of parts that need to be powedercoated so i decided to spend time with this task first: 1) On my way home from work i stopped by the garage because i had a good idea during work. I Finally found a solution to remove those rear subframe bolts from the chassis (the ones that bolt to the moustache bar): The wheel-torque wrench with a long shaft and a metal-tube extension finally got them out. Thesre are pretty special so no possibility to get those new. I had to get them out for zinc plating. They have a conical shape with both threads on the top- and lower end. 2) Before i went home i made sure to pack up all the parts i need at my home-workshop during the next days. because my garage is a few minutes away from home... 3) Decided i need some parts zinc-plated from the pedalbox as well and all the bigger bits need a sandblast and powdercoat so i started the dismantling. Before: And after: Still need to dismantle the steering column and safety-harness mounts and some other parts before sandblasting / Powdercoating and Zinc-plating all the bits. THEN finally i will hopefully be able to move fast forward with assembly of many small things...
  8. It seems like every post i write starts with a "finally". So this one is no different: Finally some Assembly work started. After many years of taking parts apart and cleaning them, finding replacement and doing research - i started the assembly of the Steering rack-and-pinion system. This is how it started (Note the new workdesk light i installed also ) I highly recommand using these Surface cleaning pads (pot cleaners) for removing old dried-out grease, slight s urface rust and dirt. Works brilliantly and is super cheap and easy to get Also love my new multi-purpose grease pump It's so much fun cleaning all the little bits like the grease seal seen here: Looks like i didn't do a lot but after two hours of cleaning surfaces, degreasing, re-greasing a lot of bits and puzzling it all together i ended up like this Still need to get a few parts zinc-plated before i can complete the assembly but at least i have something like an almost-finished steering rack Then bought a simple spring-scale from an online auction so i can make sure to have all the parts within specifications as mentioned in the service manual. No the most high-tech thing but it was cheap and wil do the work for me Also got a little delivery with some Nissan OEM Fasteners that were on back-order. Now have most of the parts ready for a full subframe re-assembly with all new OEM bolts. still need to get a few replated but most of the parts are ready. this will be fun Also got some updates from the bodyshop. He's currently working on the Framerails, battery-tray area and the passenger-side firewall. I'll let the pictures speak. please note that most of the work is not completed yet, so it might look a bit like a hackjob - but you have to wait until it's done That's it for now. hope go get the parts ready for zinc-plating soon because this will give me all t he missing fasteners i need to move forward with the subframe assembly... Now taking a day off and go to the Zoo
  9. Jepp, progress is currently a bit slow because i'm still working on a lot of research stuff and the weather is cold and snowy over here (and you know my garage is unheated). However got some small stuff done again: Ordered a big bunch of OEM Nissan Nuts, Bolts, washers and springs for the rear subframe assembly. Still a few missing they will be delivered delayed. Also finally got a little update from Yves over at MUC. He's currently preparing for exchanging the Genuine frame-rails i brouth him a few weeks ago (See below):
  10. thanks mate. Bought it on Ebay in Washington, got it shipped all the way to switzerland. but very happy with it. Has been laying in a barn for many years Same for the Framerails. Almost impossible to find NOS ones but i found some. Patience is the key
  11. Hey guys. some of you might know me from a lot of other Forums. I'm from switzerland and own a few (over here) rare cars like a JDM EK9 i imported a few years ago and love to drive. However 4 years or so ago i decided to get something classic and after a while i found myself in the middle of a huge Project. you can read a full build thread from the history till now with a ton of pictures and specs including a lot of rare parts here: http://japanesenostalgiccar.com/forum/viewtopic.php?f=7&t=11769 But for all that don't want to read through 29 pages of a build i decided to make a short version here and will update it like the other build threads in future: 1) Bought a car without carbs and a few dents and stuff like this in 2010: 2) had it stripped down to bare shell and put it into a rotisserie in spring 2011: 3) figured out the chassis was shit due to a lot of bad repair attempts but then got told about a cheap Z near me which was for sale so i checked it and bought it for 300 Bucks the next day. was also in bad shape due to standing in the snow without a sunroof fitted, but was so cheap and at least it was all original and not too much fucked up. i had to have it... 4) a few months ago i had the second car stripped to bare shell as well and put it on a rolling jig and sent it to the bodyshop for a ground up restauration which includes a lot of metal fabrication: 5) this is the current state at the bodyshop. will stay a few more months there but will keep you updated: I have also done a lot of things like reworking all the subframe parts and had them powdercoated and bought a lot of stuff. some pretty rare things like - Bride histrix seats - OEM NOS Framerails - New OEM Roof without sunroof - Kakimoto valve cover - hayashi racing drum brakes - Watanabe Falcon steering wheel - Saito Rollcage - and a ton of parts from Nismo / Kameari / Tomei / Omori / Koyorad / Rocky Auto / Tokico / Kyo-Ei / IPF / Trust / Greddy / Nagisa Motorsports / Autorefine.... Currently ordering all the the OEM Bolts from Nissan (a lot of work to get all the partnumbers,...) and trying to get some information on some rare oldschool Intake manifolds (if someone knows anything about the "Ohtsuka" intake manifold - please let me know!!!) However still need a lot of parts. if you're interrested in all the details click the link on top. will document the build detailed from the current point on here as well
