Blob1620 last won the day on May 23 2016
Blob1620 had the most liked content!
Gender
Not Telling
Location
Lawrenceville GA
Recent Profile Visitors
6550 profile views
Blob1620's Achievements
Well, after much toil and lost sleep, i found a place at the top of the gearbox that was touching the trans tunnel. Vibration gone... Happy days
I've had all I can stand. I'm going to pull the gearbox this weekend and get the flywheel/pressure plate assembly balanced. As far as I can find online the RB's are totally internally balanced and shouldn't require my machinist to account for a counter balance. Is that correct? Going to have a better look at the top side of the gearbox too and see if maybe its been touching anywhere I couldn't see from the bottom. Wish me luck... this has been a problem since I first built the car...
Im lookig for some short front strut inserts so I can lower my front more, and Im running Cosmo coilovers so they need to be fairly agressive valving to keep up with the spring rate Im running. I cant justify buyimg new ones... New struts and camber core tion kits cost as much as simply buying real deal coil overs.... Which are also easier to modify the car for haha. Anybody has somethkng to offer let me know! Thanks!
Ok, I bought one of those sheets from Home Depot after reading that the PVC foam is actually quite rigid. We will see. Expect photo's and a write up here once I start digging in.
Yea, been looking at Birch, I've used ABS in the past but its pricey. Just wondering how this foam PVC holds up and cant find specs on temp range or tensile strength.
Has anyone here ever worked with Palight PVC plastic sheet for building a splitter/undertray? Seems cost effective (48"x24" sheet shipped for $57) and short of a temperature rating seems up to the task. Im just seeing who, if anyone has worked witb the product and seekng if its viable for that ise case. Cheers!
Hi everybody, Has anyone used an a header manufacturer they liked for a low mount application. I see high mount stuff all over but I'm using a t3 hot side turbo with an internal wastegate and I'm looking to keep the turbo in the same location the stock manifold has it to avoid redoing the down pipe and potentially being forced to change turbos. This one looks well made http://www.ebay.com.au/itm/TOG-NISSAN-SKYLINE-R32-R33-R34-RB20-RB25-LOW-MOUNT-EXHAUST-MANIFOLD-/121450731122 But then theres always the temptation of saving a bunch of money by going with the GodSpeed style t-304 stainless header. http://www.ebay.com.au/itm/T3-RACING-TURBO-MANIFOLD-EXHAUST-FOR-85-99-NISSAN-SKYLINE-R31-R32-R33-RB20-RB25-/191291485916?hash=item2c89dc6edc:g:X~gAAOSwHnFV6dq9 Anybody have opinions on this?
I did the ls2 coil swap with the mojo performance bracket, connectors to modify the harness care of wiring specialties. the picture was taken half way through with the wiring not yet complete, but it gives you the idea. Initial impression, big time improvement. still a vibration at 3k rpm but come to find out my FPR is failing so theres a new one on the way to fix that. this thing should be pretty angry when its done.
Another Shock thread... Sorry
Blob1620 replied to Blob1620's topic in Brakes, Wheels, Suspension and Chassis
Where are people buying these at? I'm having a hard time with local parts stores getting them. Also, is it the same part number for fronts and rears? -
Im on a budget and looking to find as many of these things as possible second hand. - r200 long nose with a limited slip - tail light interior plastic panel for a 280z - short shocks for sectioned strut tubes - aftermarket rear control arms for camber adjustment Anything you can bring to the table would be appreciated. Thanks all, and Happy New Year!!
Happy Thanksgiving everyone! I've been driving my car for about 2000 miles now, and everything seems to be coming in nicely which has me thinking about the loose ends that I still have yet to take care of from the build. I have a Cosmo coil over kit which runs higher spring rates than most of the other kits, I think it's 300 pounds in the rear, and 250 or so in the front. I have to double check that for sure but I know it's higher than most. Anyway, it's time to start considering sectioning the struck tubes, and that has me looking for shock incerts. The shock thread that's pinned on this forum is like reading a novel… And it's kind of old. Is there any sort of new product that anybody would like to share? Also has anyone used the actual Cosmo coil over kit with a shorter strut successfully? My goal is to actually have a spine left after driving this car long distances As you can see from the attached picture, I'm using stock length struts. And it's keeping the nose quite high. In the twisty mountain roads it causes a bit of corner entry understeer, and it doesn't look all that great either… The Koni orange shocks that I'm using right now seem to keep the springs under good control, but they are at the maximum setting for their adjustible valving. Any advice would be appreciated
tried a big ol' breaker bar on the crank pulley, seemed pretty tight. To be honest, my biggest torque wrench only goes to 200Nm so I'm not sure just HOW tight it is.
Oh boy, Thats bad news..... I'll have to take a look when I get home tonight... Thanks NewZed
That's just it, I purchased the engine rebuilt, I never heard it run before first fire up after the rebuild. I've had RB powered cars before though, and this kind of vibration is very new to me. Higher revs and and it comes in like waves of vibration. I'm just trying to pinpoint it without throwing parts at it and was wondering if anyone had seen this before. Removing the trans is a real pain in the balls if its not the clutch or flywheel that's the issue.
