Jboogsthethug
Everything posted by Jboogsthethug
  1. Yesterday I figured out block sanding a bit more, was doing it wrong, of course, but now this method should be easier. I'm a self employed filmer/photographer, so I have a lot of free time when I'm not working and I use every ounce of it on my car. I probably sanded 8 or 09 hours, but I had caked it on from the get go and didn't sand as I went which is where I messed up haha. I bought a harbor freight air block sander and that hopefully will help! Harbor freight can be really cool haha. I finished the dashboard! I am pretty stoked with the outcome! You can see through the pictures the evolution. In all, I re surfaced the low spots 3 times with the body filler and then did 3 coats of bedliner (after the 2nd I sanded down just a bit to get rid of the slop). partly sanded fully sanded wet paint a couple of sexy shots The detail, I liked the outcome this is the bedliner I used, anybody used it before? I've been told (after the fact) that it's not good? turned out pretty nicely! also, almost finished sanding down my doors, they are looking mighty fine and straight! I think I'm getting the hang of the body filler stuff! as far as the body itself, I haven't had a chance to work on it for the past 2 days. It keeps saying it's going to snow then it doesn't. but tomorrow I'm going to crank out some work on it. I hope I am able to get a ton done! I also was able to paint the front wheel wells (after masking everything off) and I started on the top of the cowl. I keep running out of paint haha. I also had to grind down a bunch of body filler then start over so I could actually manage it haha. More to come! I've got 25 days to get her painted and put together! Wish me luck! J
  2. alright, so the past little bit on the crap weather days (there seems to be more and more with it getting closer to winter), I've been working on little pieces (as I stated in the above post). I finally got around to painting some. I tested the durability of the undercoating I bought with a wire wheel and I was happy with he results, definitely seemed durable enough! so, I used that to paint it! I also have gotten a bit more done with my car, and I'm getting better with spot welds! I also came across this dash repair thread http://www.classiczcars.com/topic/22325-dash-repair-processpictures/page-1 thanks to my friend Terry's info, and I've been testing a few ideas off of it. I changed up the main repair material they used to somer evercoat stuff (also from the SW store) that is supposed to be good for plastic. used the great stuff to fill the gaps after grinding it with an 80 grit disk. after that I stole a guitar string off one of my old guitars and cut the extra foam off. sanded that down by hand.. and spread on a mess of goo! I'll update more when I'm ready. the weather looks crap for the next few days so it's perfect for the small stuff. I'm going to coat it with bedliner for the texture, I've heard of a guy doing that and he was happy with the outcome, we will see! J.
  3. yeah dude let me know!! THat's kind of what I'm thinking, just reach in with a brush! I'll see if I can find it as well. thanks dude! we are stoked, I'm hoping to drive away in this, we will see!
