ZIPPY
ZIPPY last won the day on July 11 2014
ZIPPY had the most liked content!
About ZIPPY
  • Birthday 05/13/1986
Contact Methods
  • Website URL
    http://www.ultimateyota.com/index.php?option=com_content&task=view&id=81&Itemid=210
  • Gender
    Male
  • Location
    San Diego, CA
ZIPPY's Achievements
Newbie
11
  1. Actually Stahl is building and selling L28 headers again. I talked to Jere on the phone recently and he told me he had initially decided to drop the datsun stuff, but some other plans changed and is takin orders again.
  2. Wow that pretty amazing! I would love to get ahold of the programming he's using there.
  3. Very nice... Did you make the actual throttle bodies themselves or are they a premade unit that you fabricated the rest of the manifold around?
  4. I think the 290F cam looks a little better. Keep in mind that the advertised power band is still 3500-7500rpm. In your case with the L24 I imagine the powerband might be a little higher than the advertised. Unless your going to be living in the 7000rpm range is it worth having a cam that comes in at 3500+? The 270-80F grind makes some real power in the upper ranges (200hp+ with SU's) but is also relatively streetabel at normal driving rpm. ITM flat tops. Hit 7900rpm fairly regularly. I think they might have very lightly kissed the head though. For cast pistons, I think they are very well made pistons.
  5. That is a huge cam you have there, looks to me like it should peak right around the 8000rpm range. To really take advantage of that cam you will be revving well past the pratical limits of cast pistons. It sounds like you are putting some money into this engine, and a piston coming apart at 8000 rpm would utterly destroy a very nice build. With forged pistons you will be to fully enjoy your high rpm horsepower with the peace of mind knowing that it won't scatter itself all over the place. Extra cost for pistons now, or extra cost for a new engine later? Or rev limit an 8000 rpm engine at 6800 rpm. I took my high compression cast piston engine to nearly 8000rpm on the drag strip a handful of times, but I got lucky and the only thing that happened was my pistons started knocking their skirts off. Also I would get as aggressive of a port job as you can afford. You have a very nice exhaust and intake system, and you are already putting big valves in the head... Don't settle for light porting.
  6. PM responded too. Sorry it took me so long.
  7. I have a cam you might like. It is a Schneider 270-80F. I used this cam for a while and then had Jerry at Schneider re surface it for me so it is practically new again. This cams duration is 270 intake and 280 exhaust. 0.460 lift. It doesn't look too radical on paper but I was making over 200 rear wheel horsepower through SU carbs with this cam. Streetable but with lots of power. I also have rocker arms that have been resurfaced and then coated with a bake-on dry film lubricant.
  8. How much are you looking to spend on one? I have a brand new Kamari adjustable sprocket. I forget how muck I paid for it, I'll have to check.
  9. For forged pistons on the cheap side look at Supertech Performance or Probe forged pistons. I know they make ka24 forged pistons for a lot less money than your usual names in the piston industry. Search their websites, find the part numbers you want and then fine th best price vendor. If you want a custom set, talk to Elmer at Arias Pistons and he will fix you up. From them a complete custom set with rings piston pins and locks will cost about $900.00 out the door. They make an amazing product by the way.
  10. That's a nice looking oil pan there. I like the windage baffles. I have a question for you about the pistons. Can you tell me what your final valve pocket depth ended up being? I am having some custom pistons made right now and I want to compare numbers, maybe I can save myself from having to depen the pockets like your machinist did. It's funny how similar your engine setup is to mine, my head is way cut down, and our cams are very close too.
  11. I'm bummed I missed MSA this year, I would have liked to see that thing run. My Z wasnt ready anyway. What did you make on the dyno this time?
  12. Oh yea, I build those all the time... Its childs play, lol
  13. tI like that tensioner design alot. I have been toying wiht the idea of making a roller tensioner similar to the kameari design. What did you construct the slack side back out of?
  14. The same car is for sale again, but this time dressed up like an SR-71. http://www.ebay.com/itm/Gas-Turbine-Engine-Rat-Rod-Jet-Car-Rocket-Hot-Rod-SR-71-Datsun-280zx-/150819504364?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D150762213305%26ps%3D63%26clkid%3D9027905810348964004 He says the tail numbers have a secret meaning and if you figure it out he will knock off $500. @ TonyD - I imagine somewhere in your vast wealth of semi-useless information you might have a recollection of what this number signifies.
  15. My currant project is a nearly 14:1 compression E85 L28 with webers. Depending on how hard it is to get the engine started I was thinking of building an ether injection system as is used on some diesels. The diesel system consists of a pressurized ether canister and a push button operated solenoid, that delivers a small shot of ether to the manifold as a starting aid. I am deleting the enriching circuit on the webers and will be running a fairly large camshaft so I imagine I will have some difficulty getting the thing started in the morning. I cant say I've ever produced ethanol for motor fuel, but I will admit to being able to cook up a couple gallons of a much tastier variety. It is possible that there are two gallons of 160 proof brandy on my counter top waiting to get cut down and aged right now.
