teknomage
Everything posted by teknomage
I would be interested in one possiably two, but I am going to vote for a flange so I can bolt my holeset He351VE. Actually a T3/T4 flange would be awsome, I can alwayse make up my own adapter, and or since these will not be cast iron I could weld on my holeset flange.
I actually just added headlight covers last week, since I have logged my best fuel mileage yet 56 mpg at highway speeds, (...due to a 30+ mph tail wind ...) Underneath the bucket covers I also added H4 headlight lenses with HID bulbs and ballasts (I need to fix the wiring harness to light them off though, not getting enough voltage to trigger the ballasts)
So I added a pyrometer in the turbo manifold on the #6 exhaust valve port. I am seeing the following EGT's idle 200-300F cruise 450-550F climb 750-950F these are well below the max for diesel egt of 1300F. The biggest limitation I am seeing is under high speed full throttle, I have observed a coolant temperature spike. I think this is due to all the heat being dumped into the coolant around the pocket combustion chambers. I hit the governor at 115 mph which I think is 4500 rpm or so. The forced induction of the turbo has reduced smoking and soot in the exhaust, especially when climbing a hill in 5th. Which would indicate more complete combustion of the light oil. I am averaging a solid 40 miles per gallon city/highway on 70-100% Vegitable Oil To my dismay when Datsun came out with the raised trunk they reduced the fuel tank capacity from 17.5 to 15 gallons, that cost me about 120 miles of range. Longest trip on one tank so far 630 miles. When I finally ran the tank dry, I dumped in a quart of rotella engine oil to get a couple more miles to the fuel pump. Smelled funny but ran well on engine oil In 77 why the heck did they re-engineer the trunk like that? My 76 fit a full size spare, has a 17.5 gallon tank, and more cargo space! Seems like they had it right the first time...
"The Di 3.0 or 2.7 that was in that same model in 99/2000 and 2005 would work for me" Tony D same model of what? would the 3.0 or 2.7 DI bolt onto the Z's engine mounts and bellhousing? What is the model name for these DI engines?
the nice photo blue72 pulled up for us on the LD28T to my trained eye appears to be a marine LD28 (which would have 3 compression rings (slow)) as the intake assembly has no provision near the entrance for EGR. This is not a stock LD28T but a LD28 Turbocharged, The down pipe on the turbo is very stock 280zx ish as is the manifold, but the heat shields on the turbo are new to my view. Clearly the PCV vented directly into the pressurized intake is not a foo bar that a great engineer like datsun would make, so I would have to chock this up to being non stock.
I have heard many say that "The LD28T is available in Europe, as well as through marine and industrial outlets. They were in Forklifts, etc." But in all my thorough research I have not turned up any such documentation, just heard everyone stating it. I do know the LD28 came out in a marine derivative but that is all I have ever seen documented. Never turbo charged and never in a forklift, I am not saying this is not true or possible I just have never turned up the empherical evidence of such. Please share if you have it, especially the specs of a factory turbo charged LD28 including the max boost, and any alterations that were made to the base engine to do such. which flows exhaust more easily a higher A/R like .065 or a smaller one like the .45? Not sure what all these turbo specs mean is there a clif notes guide online to understanding turbo specs? The N/A fuel pump has an aneroid (evacuated brass billows) as an altitude compensating emissions feature, I am not certian but I belive this mechanism is identical to if not the same as the aneroid used by bosch on thier turbocharged fuel pumps, only one has a hose barb and the other a filtered port to atmosphere. Either way thire function is the same sense pressure density and actuate a fuel delivery cam porportional to the elongation or de-elongation of the brass billows. More air pressure compresses and de-elongates the billows pulling the fuel delivery cam open, akin to driving your LD28 below sea level, say the marinarias trench below....
my rear end and 5th gear are stock 77Z 3.545 R200 and .0864 turning a set of 205 70R14 tires which gives me a top speed of about 113 at the governed 4600 rpm. At 60 mph I am turning 2442 rpm, the engines torque peak is at 2200. (FYI anywhere the torque peak is for your engine is typically wear you have the lowest brake specific fuel consumption, you should gear to be at your cruise speed right on top of your torque peak for best economy) Yesterday I took a road trip with the aneroid disconnected and achieved 50.34 mpg at a steady state 60mph with a climb over a mountain pass from 5000 to 6700' and a distance of 57 miles. It cost me $2.80 to go that 57 miles I have a 82 5 speed tranny I want to swap in with it's .0745 overdrive, and I am on the hunt for a good 3.364 R200 out of a 79 4 spd manual if anyone has one pleas PM me. If I get this combination it would move my best speed on the torque peak up from 54 mph to 66 mph When I upgrade my rims to some solid disc salt lake racer low profile style 17's I should be able to raise that best speed with a larger diameter tire. For now I am going to wear out the rubber I have. What is the fuel tank capacity in the 77Z? if it is still the 17.5 gallons I have a highway range of 880 miles!! I have checked out the Aero sub forum, and will continue to do so for notes to polish my grand touring sedan project... the bosh VE pump used on my 2 LD28's both have a rheostat on the throttle bell crank that can be used for logic, such as the manifold pressure to aneroid solenoid. This is an altitude compensating aneroid so how well it does at boost compensating is in question, but it is there and better than nothing. I am actually quite pleased with the performance without any compensation. With the turbo packing those cylinders with more air molecules. Again once I get a few more things done I will get us a dyno run, hopefully even a dyno diesel tune On my ride I want boost compensation selectable from the cockpit so I can be in boost making additional power and choose when to use more fuel, for yet more power. What I have determined with certainty is this. with manifold pressure communicated to the aneroid under normal highway conditions I get 37 mpg with it disconnected I get 50 mpg, weather or not it is connected I feel additional power from the turbo surge. the stock 280zx turbo on the LD28 is making boost above 20 mph even when out of the throttle at a light and even steady cruise state at 60 mph level steady cruise where I am barely depressing the throttle I am getting almost 2 psi of boost, simply due to the amount of air the unthrottled LD moves. I will be making a elbow to temporarily replace the turbo between the manifold and my exhaust while I rebuild my worn junkyard turbo (I am loosing oil out the shaft seal into my exhaust,, stinky). While this is done I will take a couple trips and note the mileage with this combination minus the turbo exhaust restriction. I would like to determine with certainty, weather the boost created by restricting the exhaust and capturing its normally wasted energy improves or reduces economy. I would also like to determine weather cooling the induction with an intercooler improves or reduces economy. At some point I want to go to a Holeset VGT turbo and link the VGT to the TPS in some fashion. thanks for the forum on the LD28's will be joining and parsing. I get real funny looks pulling up to the green handle in my z, about a third of the time the dude with his head cocked to the side comes walking over to ask what the hell did I do to my Z, and leaves thinking of building something similar. I have a 2nd LD28 on the engine stand to build up wild, I am contemplating swapping a complete cummins fuel delivery system and turbo onto it that is OBD2, and building it for big boost, I will do everyting I can for power without sacrificing my great economy and durability on this engine build. Tooday I am finishing my induction with a ram air filter intake centered in the air intake in the chin spoiler.
I just got my 1977 280Z 2+2 on the road with its turbo intercooled ld28 diesel engine, power is more than sufficient, but at 800+ miles to a tank and the ability to go on road trips free using restaurant waste veggi oil, I am loving it. My bull mastiff is loving the extra space in the back with the seat folded down you can take a look at my ongoing fuel log if you are interested in real world fuel mileage with this combination: http://ecomodder.com/forum/em-fuel-log.php?vehicleid=2731 This link will take you to the ongoing spec for this car as I customize and hybridize it. http://ecomodder.com/forum/emgarage.php?do=details&vehicleid=2731 I took thorough pics of the swap and can talk details to any one who needs just drop me a PM to answer some of the questions in this post: I am using the stock 280zxt turbo and manifold (get out your grinder to fit it) with a custom down pipe and 3" mandrell bent exhaust with two borla straight through glass packs (for a throghty but quite cruiz tone, I like to talk to my girl on the highway now and then). No angles greater than 60 degrees in the exhaust. I am seeing boost building just off idle with 1 psi by 30 mph, and 4.5 psi by 65 mph on an easy steady level cruise. The LD28 is a unthrottled diesel so it takes all the air it can get and needs no pop off valve. Diesels are variable air fuel ratio engines so you just add as much fuel as needed for the power you want, any excess air is just a working fluid for high temperature gaseous pressure to exert force on the piston. That said when I connect manifold pressure to the aneroid on fuel injection pump additional fuel is injected porportional to manifold pressure density. Power and accelleration are great and fuel mileage is in the high 30's Disconnect this line so no additional fuel is injected under boost and the engine runs extra lean (no problem for a diesel) I still feel the turbo surge but the power is less and I get in the high 40's for miles per gallon. I will be adding a selinoid to only allow manifold pressure to the aneroid at the press of a red button on my shifter, this button will run a few other things like a shot of steam on the turbo turbine to spool it . As I bring this project all together I will get a dyno run for us to google at. No modifications need to be made to the LD28 untill your boost levels approach 20 psi, I read one case history where the stock tired head gasket let go at 20 psi of boost. Just replace it with a better quality head gasket and head bolts if you blow it trying to go with max boost +++ I plan on using the condensation tank in the rear passenger quarter fender as a 2nd fuel tank in a dual tank svo system holding keroseen for easy starts, warmups, and shutdowns. Switching to the main tanks full of veggi oil for cruzing. I might even add a parallel hybrid electric motor on the driveshaft for short runs to the store and back without firing up the engine, or for a little more scurry One indespensiable guage you need to add to your cluster is an egt pyrometer on the number 5 exaust port and keep it under 1300 F and you have a Z capeable of a million miles! diesel is a lubricant gasoline is a solvent how long is your engine going to last? The LD28 for this project came out of my 81 nissan maxima manual that pulled the stock 77 Z 2+2 normally aispirated from fresno california up el cahone up black rock to the high plains desert in milfort utah at 5500 feet above sea level and averaged 38 mpg on the highway pulling a whole other car near its own weight............. Enjoy, and please comment.
So what is the normal lifespan of a rebuilt stock turbo? Tell me more about this center section that was upgradeable to ball bearings? Was it water cooled as well? What are the merits, plus and minuses of going to a water cooled center section? Thanks a bunch for the contact info, I will get a hold of those guys, and discuss my options. As far as my Z goes it is not difficult to go with more turbo, it is Diesel, a LD28 based Z and the fuel injection pump has an aneroid that adjusts the fuel injection pulse proportional to the air pressure density in the intake manifold after my intercooler. Everything in the LD28 is burly to handle the detonation of compression ignition. I seem to recall having read a case history that the LD28 looses its head gasket at around 20 psi of boost, I have a long way to go to get to those levels, with the stock turbo and waste gate, and the unthrottled LD28 engine that gulps all the air I give it, I am seeing the engine start building boost just above idle, by 65MPH steady easy level cruiz about 3 psi, and at 85MPH steady easy level cruiz about 5psi of boost. I am not looking to go real wild, just reasonable performance, good mileage, and not feel altitude sickness in the mountain passes I regularly traverse.
From the album: My 77 280Z 2+2 turbo intercooled diesel
Images added to a gallery album owned by teknomage in Members Albums
Well it looks like it is time to rebuild my stock turbo, I was wondering if any one out there had links to locations offering rebuild kits for our stock 280zx turbos. Also what type of turbo is the stock 280zx turbo? Is it a straight T3? A T3/T4 hybrid? Or something other special? If I opt to just replace the turbo rather than rebuilding what turbo's will bolt right in without needing to modify manifold or exhaust? a T3? A T3/T4 hybrid? What are the advantages of the T3/T4 hybrid?
