240zJon
Feedback
0%
About 240zJon
- Birthday 06/04/1989
240zJon's Achievements
10
i dd my 240z and man she is a *7#ch in the morning to start withthe carbs. its starting to get colder up here in oregon and every time i crank her over she almost drains the battery. so i think its time for something new...
Okay so i have a 72 240z that has really hard brakes. after reading some post i have come to the conclusion that its my booster. so Is there any years that i can switch it for. im cheap and dont wanna pay 150 for one from auto zone. i searched but no luck. thx
Hi i need a efi External inline fuel pump for my 240z that im switching over to efi. I don't care what brand it is aslong as it will do the job. PM me a price and what you got
Yeah maybe i should just try and rebuild the carbs but i like the dependablity of efi... the PO swapped it over to efi at one point then back to carbs. It still has the wiring harness ecu and a couple other things i just don't what it really needs also If i get a harness from one year and a ecu from another are they compatable? wheres a good place for cheap fuel pumps besides the junkyard lol.
okay so i got a perdicament my 72 has the su that are starting to crap out on me. I almost drained the batery trying to start it in the cold. So im looking for somenthing else and i found a holley carb and AZ intake for 150, I also found a motor with EFI for 250. Now my question is what wold you guys go for? i need some insight. also if anyone has swapped there Su are you happy with what you got now? IM kinda on a Tight budget of around 350 if i buy the EFI. is it possible to do it that cheap?
no... how would i check that? im not real sure onthat they even do?
well i figure my vltage regulator is dead since my battery keeps dieing, but my alternator is still pumping out around 12 volts. so my question is i know theres a few different alternator i can swap in. with the 85 maxima one would i have to run new wires to stand the higher amperage? also has anyone bought the voltage regulator plug from MSA?? was it worth the $20. What have you guys done with your charging systems? my cars a 240z 72 with a 280z motor with carbs on it
hey, thanks i'll try that tomorrow, right now i have them set at the standard 2 full turns down from the top. hope it works... also what should the floats be set to? in the manual its 14mm or .55 in, is that a good gap setting for worn carbs/ floats? i have them now around 1/2 in
Okay well my problem is a confusing one. i took my carbs off yesterday to readjust them for a camping trip i going on, but after awhile of fiddling my car wouldn't start again. I've checked everything; it gets gas, has spark at the rotor and im certain there is gas in the bowl. the problem is that the car seems to not be getting fuel into the carbs themself. does anyone hae some guidance? i pump the pedal, choke everything i can think of and nothing happens. They're 3 screw round tops on my l28
Hi Me and a couple of buddies are planning on cruising our z's soon. Do you guys have any ideas on some cool places to see/ camp at or some good roads to cruise on .
okay well i think i got it somewhat tuned. now when i drove it around i got 45 miles on ten bucks or about 4 gallons. so im not as bad as before but its not the greatest mpg. im still leaning towards efi for it so im keeping my eyes open for one or if anyone in the NW has one for cheap pm me.
I need to know were i can pick up a new or used antenna grommet on my 72 240z. Right now it doesn't have one and when it rains a ton of rain gets in. Does msa sell one or something?
i Was to cheap to buy a uni-syn so i tried the old hose to ear trick and i think i got them pretty well balanced. my only problem now is the fuel mixture. i have the front carb pretty well mixed... i push up on the piston and it doesn't sputter or rev high. my problem is the back carb. i've pushed up on the piston and turned it richer each time because it sounds like its going to die. so i guess i'll just wait and check the plugs in a couple days and see if they're fouling
okay today i did another test with a different gauge and got 100 even when i pulled all 6 plugs. Also i took both carbs off the clean them out and see if the floats are set right. I don't have an air flow meter so i can't really tune them right so im waiting on that. What the best tool for sensing the cfm on the su's, i hear unisyns are kinda useless. Any cheap but effective tools to use?
okay i found a motor and trans with 40,000 mile rebuild for 300. it comes with all the bits and pieces would it be a better choice than rebuilding the carbs? also i did a comp test and my cylinders were around 100, is that bad?
