Thanks for the info. I plan on buying everything to rebuild the head. ( valves, guides, seats,spring set, rocker arm guides, etc..) it really sucks you can't find new lifters. I should just change them with mech.
well my plan is to rebuild the head. as for the block i was going to change the piston rings, main and rod bearings, and a good head gasket. Then install a new timing set, water pump, and oil pump.  I think with these thing done a should have a good reliable motor. I really only want around 250 horses. what do you guys have done to yours. oh, how hard is the wiring for swapping the l28et into a 1975 280z.  can i just use the stock wiring but change the computer? What about megasquirt? Is that hard to use?  I can do almost anything mechanical but wiring is my downfall.
thanks again for all the info....
