Hey people. I've been reading posts on this board for a while, and I've decided to do a conversion too.
Originally, I was going to spend my money on a new 370z (at least the money I have for the down payment) but I'll wait until next year for that. I currently have a 5-speed '90 300zx N/A. I bought it mid last year and LOVE it. Before that I had a 2002 WS.6 Trans Am that was stolen. I miss it and the power of the LS1. But honestly, I love the way the Z32 drives and feels more.
My current Z is mostly stock and runs really well. It has low miles for it's age (about 7K a year) and it's pretty clean, inside and out. But that's not the car I want to convert. It's reliable right now, and as they say "If it ain't broken, don't fix it." So it's a good daily driver.
I plan to buy another Z32 as my project car (another N/A 5-speed) and my thoughts are to drop a VH45 in with the possibility of either turboing or twin turboing.
After reading a bunch of the posts, I see that it's obviously NOT easy to do this and this will be my first conversion.
I have about $12K to work with (maybe a little more depending on how much time this takes... LOL) and I figure that I should be able to do everything for this much.
Here's my questions:
1) There's been a lot of discussion about the oil-pan/X-member being an issue. But a friend brought up the point that Dry-Sump might be a better solution. The bonus would be the added reliability and some extra HP. Any thoughts? Has this been done before on either a Z32 or a VH45DE?
2) I can't fab. Never done it before, so I'll run into the issue of where to get motor-mounts and an intake that would fit under the hood. I've been looking into ITBs and I REALLY like that option for both power and reliability. I've seen some that were done for VH45's but no kits, so again, fabrication is required. If I were to force induct the motor with ITBs, I'll need to construct a good plenum which I don't think is that big of a deal. I've seen them made out of aluminum or fiberglass, so that shouldn't be a problem. Any idea what would be the best way to go?
3) I know that the power-steering pump pullie doesn't clear the sway bar. Someone on either this forum or the Nico forums lowered the sway bar with some square tubing and still needed to modify the pump brackets and ears. I was thinking that since this isn't my daily driver, an electric power steering pump may be a better solution. That way I won't run into the clearance issue and I'll pick up a little extra power. Does anyone make a power steering pump for this car with a smaller pullie or perhaps a relocation kit/bracket? I don't care if it's an electric pump or if it's engine powered.
4) I know this is practically impossible to accurately answer, but does anyone know how much power I can expect from an N/A 94+ VH45? I know the stock power, but I'll obviously be using custom exhaust, possibly dry-sump, and ITBs. I don't know much about the Nissan motors as I've been driving and working on GM's most of my life. I've been told that the stock injectors and internals were good for around 500HP reliably. I saw on another forum 600. But with N/A, I don't expect more than 400 crank. Dry sump is supposedly good for about 30-40 HP because the crank isn't slapping the oil.
5) I'm really used to having plenty of power on demand. My goal for this car would be about 350WHP N/A or 550-600WHP Turbo'd. I can always replace the internals if I go TT, and likely will, but what would I need to replace? I read that the stock crank and connecting rods are forged steel. How much power will they handle? I'm sure piston heads will be required for the Turbo application, right? At that point, should I lower the compression? Or will the motor handle it at the 10+ compression? I figure 9.5:1 or 9:1 would be better.
Anyway, thanks in advance. This is a fantastic forum!
