inis
Contact Methods
  • Website URL
    na
  • Location
    kansas city
Recent Profile Visitors
inis's Achievements
Apprentice
Apprentice (3/14)
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Conversation Starter Rare
  • Week One Done Rare
Recent Badges
  1. Hello all, I'm looking for a NIB/opened/used cxracing s30 ls swap kit. All items. I would also consider other brands. Please pm me, located in Kansas city and would travel to pickup if possible. Thank you
  2. Yeah I'm sure it's not right. I have a new timing set amongst things coming my way. Thanks for the link I'll grab that too.
  3. Hey update, engine released tonight and spins freely. Chain wasn't the issue just needed to soak a bit more. Walls look decent, ill have to inspect more but problem solved. Thanks everyone.
  4. Yeah can't spin. Bought it with tubs of parts, block is still mounted in car with no head or oil pan. Has sat this way from my understanding 10years. I was told the orginal owners son drove it. Blew the head gasket. The dad aka orginal owner took it apart and never put it back together. The head looks professional machined with valve terrain still in-tact. If I can't get it to spin, I'll take it to a machine shop and see what can be done using as much as possible orginal parts. Might just need disassembled and a light hone job, new bearings, new rings, main cap bolts, rod bolts and then reassembled. I'll expect the worse and hope for the best. Current as it sits, I haven't been able to turn it at all, not even a mm. Best I can tell the timing chain isn't bunched up.
  5. Yeah non-scratch kind. I've built engines before and no concerns about rebuilding it as is. Going to lay underneath it today to see why the pan is off and maybe pop the pistons with a rubber mallet too.
  6. I'm a very fortunate person as I have been looking for over 4 years for a mechanics special. I came across (and purchased a 1 owner 260z with 70k miles. Story I got, he blew the head gasket. Took it apart and never out it together. It's been garages stored for 15yrs since that happened. Car is 100% time capsule and documentation goes back to 77 best I can tell. This weekend wife and I started go through the parts and verifying what it will take to get her on the road again. First part, we can rotate the engine. Sleeves and deck had some rust but scotchbrite green cleaned almost all of it up. Engine has soaked for several days now. But I'm wondering if there is more story here. The oil pan is off. Is there a reason someone would remove a oil pan for a head job? Best I can tell deck and head are flat. Going to give it another go tomorrow and if doesn't budge next weekend I'll pull the motor.
  7. got to it alittle bit yesterday. Weather gave me a 2hr window. I got the rear hatch area clean. Front of spare tire is rusted out, didn't look bad to patch. Rear hump behinds seats, drivers pocket/door access looked great almost new. Between the two covers there is alot of surface rust, right (passenger side) hatch around the lip had alot of surface rust. Overall really not bad. I did get a chance to pull up the carpet on both sides around the seat. Lets just say there is no floor left lol. Passenger seat is more or less a steel frame with covers falling off of it. Frame is loose however functional. Drivers side seat is not functional and same scenario otherwise. From what I can see, looks like just the floor pans under the seat. More to come later this week, going to take a power washer to the interior to it after some more vacuuming. Also drivers door wont open, outside handle although in place looks to be broken internally. I can get the window down however interior latch doesn't work either. Its not clean enough inside to crawl into yet lol. After I get the interior cleaned out and inspected, I will pull off the front fenders and see the extent of the unibody damage. If its looks repairable (by me) I will start prepping the garage for winter use (no heat currently). If it doesn't I will probably re-sale the car and move onto another project or get a quote from a buddies bodyshop.
  8. Got it off the trailer today but the rain became to much to do anything more. So far all the drip rails look great, all of the hatch area too. I'm hoping the upper front unibody isn't to bad. But wont know for a few weeks. Need to do a garage rearrangement to get this inside.
  9. Yeah plan is to clean it out and remove front clip/ engine. See where I'm at then. It's hard to tell but once we got it on the trailer the drivers side is pushed up higher and left is mostly straight. If I was to guess someone ran a 3 way stop and went into a ditch hard. I have a tig welder, I'll do what I need to for the front end. Hoping as I did into it more that everything is able to be replaced/repop and not needing made by myself. Engine cradle did look twisted too.
  10. Do they front frame and walls? At the car now although it looks straight the front end has been hopped. Driver's side buckled at the firewall and lower rail by the rear a arm mount. Pass side below the structure tower. Looks like it's been pulled out. Interior has 4" poop. From under it looks like rotted pans and rockets. Rear end looks great. Rear wells look bubbling possible previous bondo.
  11. I've noticed. Although I will see if the stock engine runs for giggles its going straight to a LS engine. When I discussed this with the wife she said she really didn't care as long as I didn't take away from the savings. ❤️ I told her I would get rid of the ranger and 49' 5 window for this. Its literally in the middle of no where, sounded like a old guy. I'm to far to drive for a deposit. Funday Friday, can't wait!
  12. I agree, many things have come and went that were once cheap. I'll get to check it out more this thur or fri, haven't set a date on when to pick it up. I'll post alot more pictures when I get it in my driveway.
