About RUZN
- Birthday 04/30/1979
Recent Profile Visitors
RUZN's Achievements
10
So Im building a couple Z31's. As posted previously I have been wanting to make one engine Twin Turbo VG30ETT and the other just a Gas saving semi fun car lol. So I have picked up a 1984 Arizona Z and recently got a FREE yes FREE 1987 N/A with all leather interior and Black dash and stuff hehe. Anyway in staring to Mod a customers vehicle a friend and I have notice the Z31 intake fits backwards on the plenum and still clears all obsticles. only real close part is the timing cover but it actually clears it still by a couple mills.. Anyway I will post pics as they are on my laptop I realized but we basically chopped off the side intake welded that hole shut and then cut a Square out of the Backside of the intake (which is now the front) and mounted a 240sx Bigger throttle body on that. Couple kewl things we noticed. More room to access lower parts and injectors. the Plenum now dosent hang so close to the exhaust near firewall infact there is over 60% less Aluminum to gather heat from the exhaust thus making your charge air so much cooler. Also! makes it nice for turbo aplications and NA as you free up tons of room all around. Ill post pics with Both the Pathfinder (ported) intake and stock (Backwardzzz) Z31 intake Our new creations name is: Mr. Z & Mr. 2 OEM automotive Engineering. We will be accepting cores and converting them to the new design Pending our finished product and Dyno numbers and flow charts. We hope the gains will be good overall so that all of you all can have a semi stock looking plenum without paying huge bucks for ones that might not fit perfect or have to be redrilled ect. ect. Stock fits absolutely perfect backwards hehe.. Weird hey
Did you set the diff up yourself? It sounds like you have to much Backlash from your pinion to crown gear are you sure you set correct backlash? As the gears wind up with torque they tend to seperate a few thousands of a inch. To me if its above 5mph that means the Pinion is contacting to closely or to far away. Metal shavings are generally not good even after 300miles.. Like micro bits ok as any loose material from casting will rub away. Do the bears have to much preload? Did you do a Tooth pattern check or just put it in. You should buy a dial indicator mount it and check backlash as well as tooth pattern wear.. It should be more towards Toe end of the teeth but directly in the middle. (Toe end means closer to center of crown gear, Heel mean closer to Back of Crown gear) The Differential is the center Casing Crown gear is the big gear Pinion gears are the smaller Straight cut teeth within the Differential casing Side gears are obviously on the side contacting your axles and the driveshaft is connected to the main Pinion Gear obviously Differential Housing is the outer housing that contains the Differential. Anyway I would check your tooth contact pattern make sure its in middle but slightly down towards the Toe (not to far) then adjust Backlash as needed with proper shims. Cause I think it sounds like your teeth as they load up are to high on the heel or to low on the toe or even perhaps the crown is to far right or left.. ya know? hehe lots of metals flakes usually means its to tight maybe not enough backlash or to loose to much backlash
Cant you Run Methylhydrate or something cause its 99.9% alcohol, and you'll pass? I know I ran my 240sx on 4L Methylhydrate and 20L Gas and pass smog in Vancouver B.C. Canada Oh and wouldnt replacing your muffler and possibly your whole exhaust pipe make you have a cleaner burn cause you wouldnt have all that old crap in the muffler shooting out
Yeah I think I rewired, fiddle and messed with everythign on my car before I figured out it was a Intermittant fault with my MAF sensor on my 280zxt. (ECU swapped to 300zxt and MAF).. So dont feel to dumb! haha although I have no more smog stuff LOL Go Alberta Pollution! I do try to run 94 Octane only though and Syth oil to keep down those carbons!
http://www.youtube.com/watch?v=st8BwsMHLj8 Wow amazing amazingly fast Z lol.. is that a turbo or a small jet engine LOL
Craigslist 1980 Datsun 280ZX 10th Anniversary - $16500
RUZN replied to Zmanco's topic in S130 Series - 280ZX
So other than virtually no options.. Dose it still Rust or is that not an Option..... =-) kekekeke -
OK first I`ll tell you whats left on mine. Nothing... LOL ok no seriously... I have Vacuum for Boost Sensor Vacuum for my Auto tranny and Vacuum for Fuel Pressure regulator (FPR) thats it. Everythign else I took off Except that Air flow (when cold) thingy I kept incase car would run weird but I capped it hosing here frig Ill take some pics LOL one sec... *runs outside* everything I got brass caps and closed off all other vacuums except ones shown.. Brake booster Boost FPR Transmission (auto)
Yes I swapped to Z31T ECU and MAF and 240sx TB and and and LOL all for about $600 or so I did a complete swap and upgraded some stuff like Intake and Exhaust ports ( bought a Boring bit for $40 and matched intake and exhaust inlets to Gasket and then ported the mouth of the Plenum to 60+mm as well.. Im just saying about the distibutor. I used the Shaft the bearing and all internals including the Rotor which I trimmed a bit and put it all inside the 280zxt distributor housing. So Newer bearing, newer sensor, newer rotor ect ect etc... The VG30E rotor can be trimmed on the bottom of the plastis so it dosent RUB the Dust cove rmetal thingy. and then I just got longer threaded bolts with nuts and was able to mount the newer plastic Sensor inside... I have now NO accel Loss no decel loss and only once in a while a little pop out the exhaust LOL.. but over all it starts cleaner, runs WAY better and has crazy good power I just run out of Gears in this damn 3 Speed Auto LOL but man dose it friggin haul butt now that the MAF is working! jeeezuz... Even the Maseratti guy beside me thought it had some wicked sound and some great accel! hehe.. LOVE MY WARPIG!!!Z!!
Z31 Distrubutor internals in a 280zxt distributor
RUZN replied to RUZN's topic in S130 Series - 280ZX
Yeah im a 2nd Year here in Calgary so still learning about this stuff!! LOL.. Thing is it was intermittant and really only happened under Load so its kinda hard to Test it with a Ohm or volt meter while the car is trying to tear away from the blocks LOL... It read ok when testing so I guess it must have some faulty wiring internally that gets bumpped around or what not! All I know is its freaking Awesome now! And $20 bucks 94octane atually gets me like 200km instead of 100km LOL So im HAPPY! plus replacing old coil and stuff really made a huge difference Its like a friggin new car. FUN FUN FUN -
The problem with the loudness originates from your ROUND exhaust!.. Switch to Magnaflow Oval and Notice the Camaro type rumble as opposed to the Trumpet type Howl the round exhaust makes. mines great overall being Oval and is quieter when punching it but a bit louder at Idle.. Lets you know your still running LOL..
I took my Z31 VG30E distributor apart and used the shaft/bearing/ and sensor parts (black plastic piece inside) and ROtor in my S130T distributor housing. And it works like a dream. SO if anyones having distributor problems you can order internals for a Z31 or VG30E motor. even works by using 1997 Pathfinder internals.
Oh you can use Z31 or VG30E distributor inernals as I have now found out. So instead of that old clear selant hockey puck thing with resistors and diodes on it. You can use the Nice black plastic clean looking doohicky inside your S130T distributor housing. -
IT WAS THE FREAKING MAF!!!!!! gawd... hours and hours of testing probing and I thought readings were good from MAF so must have been intermittant cause it only happened every so often GRRRRR.. Now she HAULS!!!! -
I have a 1981.5 Turbo ECU after I did my 300zxt ECU swap.. I would recommend just doing the swap to 300zxt ECU its soooooo much better!
EGR AAC all those vacuum thingies under the old AFM Chachoal cannister everything! all I have is: Boost vacuum FPR vacuum a small hose to 240sx TB from the back of the MAF to bleed in juuust a touch of air into throttle plate and Adjusted Idle screw on 240sx TB a crack open for 850rpm idle. mines stripped and now runs GREAT!
