Flippy
  • Location
    Frisco TX
Recent Profile Visitors
Flippy's Achievements
Rookie
Rookie (2/14)
  • One Year In Rare
  • Reacting Well Rare
  • Conversation Starter Rare
  • First Post Rare
  • One Month Later
Recent Badges
0
  1. I had replaced the filter with that hose as well. I had put 4 gallon gas so far back to tank, is it good for liquid the pump?
  2. Few days ago I replace a short rubber hose and inlet fuel filter because the rubber hose was leaking fuel. The car previously ran well after I replaced it and now fail to start. I can hear the pump start when turn key on, the car will cranking a second but fail to start, sounds not enough fuel is being sent to the front. A friend told me it need air out by letting pump run and circulate but I didn't know how to do it. Any hint I should look into before tow it to a shop which I believe its a small fix.
  3. Does anyone had an instruction or share their hints for 280z radio removal and replacement? I bought a 1DIN unit which try to work on but not sure if any can remove the stock radio without the gearbox armrest panel?
  4. Thx, that great info. what do you think on tire setting with 15x 8 0 offset?
  5. Sorry I guess it might be ask over hundred times. I found many answers are either with coilover or wide fender. How about stock suspension in 280z if seeking no rubbing on a 15" x8 wheel, what offset and tire setting could recommended these day ?
  6. Sorry for asking a silly question, I had a stock 280z now thinking go for 15 x8 wheel, just curious what is your experience for a tire size which won't get rubbing when with stock suspension?
