We have been struggling with Sourpuss for a while now and have not been able to figure out what is going on. First some background:
The car was running great, was recently dyno'd at 239RWHP. Then the owner came to us and said he blew out the manifold gasket and had a huge backfire out the intake. He dropped the car off for us to replace the manifold gasket. We replaced the gasket but now the car runs like crap. KPA is at 97, has no power the AFR is all over the place and the header will start to glow red at idle, even though the MS and the standalone LS1 read AFR in the 12-13 range. The engine was not generating any vacuum, I was able to get some vacuum by adjusting the timing but still not up to spec. Our vacuum gauge reads about 8" of vacuum at idle, before I adjusted the timing it was at 3". This is all on the same map that the car dyno'd on.
Engine Specs:
3.1L, with MSA Stage II Cam Kit, Ported Polished head, Lone wolf intake, 60mm TB, 6-1 Header, MS1 V3 running MSNE with EDIS, using a coil pack and controller from a 94 Ford Contour, Mustang SVO 35# injectors, 100GPH fuel pump and Aeromotive AFPR.
This is what has been replaced or checked:
Replace or checked all vacuum lines, there are only three on the engine, Brake Master, ECU and FPR lines.
Replace EDIS Coil pack and control unit.
Had MS1 checked out by Symtech and they report the unit is working properly.
We have changed the injectors, FPR, and fuel pump.
I have bumped up the timing and gave it more fuel got it to run a little better but still no power.
We also have tested the map sensor with our vacuum gauge.
The compression is 210 across the board, and we did a leak down test which also came out OK.
We have checked the cam timing many times.
I am including a recent datalog, an old datalog when the car was running correctly and the current MSQ.
Links to datafile and msq
MSQ
Current Datalog at Idle
Old DL when car was running good
Thanks in advance for any help.
Art Rinner
Sunrise Z
