Thanks for the input! I need clarification on "bypass." What are you by-passing? The Valve Assy Fuel Check?
The heat soak/vapor lock I mentioned is a separate problem. With no pressure build-up in the fuel tank due to the hole in the gas cap I still am unable to restart the engine without raising the hood (to speed-up cooling) and waiting 10 to 20 minutes.
I have read numerous posts regarding this problem (cars in general, not just the Zcars). I have not heard anyone mention that when the pavement is maybe 150+ degrees pushing hot air up, and the engine and undercarriage is around 200 degrees pushing hot air up/down sandwiching hot air from two sources (payment and undercarriage) the fuel seems to vaporize in the fuel tank and fuel lines.
Before I drilled a hole in my gas cap I drove about 40 miles in 110+ degree temperature. I stopped the car, shut off the engine and loosened the gas cap. There was so much pressure (not Vacuum) in the fuel tank that gas came squirting out in high volume. I was just barely able to retighten the cap. That was when I decided to drill the gas cap.
