kellhammer
  • Gender
    Not Telling
  • Location
    southeastern pa.
kellhammer's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
0
  1. has not set their status
  2. Can't wait to see it all put together
  3. It does look amazing. Piston what type of Breathing protection are you using?
  4. Are you using a 2 component clear? Thats one thing I'm concerned about spraying since the iso's in the paint can really have a bad effect on your health
  5. 310z I agree 225/50/16's are taller than stock 175 /70/ 14's So it should be more like 225/45/16
  6. I currently have 215/60/14's on my z with 7 X14 wheels 0" offset no problems. This was the simple upgrade 20 years ago when I first got my z BF goodrich makes a touring TA and a radial TA in the that size tire and there good quality and fairly cheap cost wise
  7. dtaylor I spotted those awhile ago but was turned off by the long order time. How long did it take to your wheels and where did you get them???
  8. My roadster. Many many years in the works. Found it as basketcase with a ton-o-rust. Previous owner had stripped it down to nothing, planning to restore, but ended up in the back of his garage. The trunk is funtional and all sheetmetal.
  9. Is it true, ROTA is coming out with a 16X8 RB series for us old school z car guys RB have a panasport look and are available in different offsets
  10. The roller job is meant to get you a half decent looking paint job using cheap paint. With your labor being the largest investment. People are attempting to get professional looking results with this method but thats not the point. Try doing a spray job without a booth or even a makeshift booth. Try to spray a two component type paint without the proper fresh-air breathing equipment. Try to spray in a garage with a temperature around 55 degrees. Inexperienced first timers would be extremely lucky to get a decent spray job and not waste expensive automotive type paint. Even with the best equipment. Spraying is complicated and the fumes are dangerous. Personally, my car is not a showpiece and the roller paint job is just what it needs to get it back on the road. No excuse for driving around with a primer paint job
  11. Use the fine white foam rollers. Like 5 bucks for a 4 pak
  12. I sprayed some MINWAX indoor/outdoor spar Urethane on a test piece. I sanded the piece to 600 grit first. The gloss is great. It might be a way to minimized the sanding and possibly polishing the whole car. A quart can of this stuff might be available. Application to the lower half of the car is my thinking. You still would want to sand the clear with 600 or 800 before applying a second and third coat for durability. The upper half of the car could get additional sanding to 1000 or 1500 grit and polished.
  13. The Mopar site has all the info on how to do this type of paint job. It's very much like the way a lacquer paint job used to be done. Prep, paint, sand, paint, sand, paint, sand etc.. The quality of the paint job was directly related to how well your sanding was done and how many layers of paint you would apply. I painted my 260z this way in 1986. As you sand you are always moving up to the next finest grit and removing the scratches and orange peel from the prevoius sanding. If some of your body work wasn't quite good enough you could go back a couple of grits and make the repair. Lacquer paint was a great way for a home DYI er to get a paint job. But, it had alot downfalls. Durabilty wasn't as good as enamel . Another reason is due to the solvents in lacquer and how it effects our enviroment. Lacquer also is brittle and would show hairline cracks real easy. Now, the roller job uses a oil based enamel and rustoleum seems to have some flex to it. It takes some finese to get a real show quality paint job but it can be done . I wanted to get as close to my 918 orange on my 73 240z so I went to Benjamin Moore and got their version of the Oil based enamel. They will custom tint this paint but I found an orange from their color chart that was a real close match. They call their enamel a modified enamel since it contains a urethane for added flex and durabilty. I've practiced with on my 240 and so far it looks promising. I mixed it with somewhere between 20 and 30 % mineral spirits. You know when it's too thin cause the paint will run real easy. The good thing is if you want get it right you can stop and add alittle paint. The roller paint process requires you to experiment alittle. If you screw something up it's easy to sand off and start over. Sanding does requires some techinque and skill. But, it's easy to get and understanding on hoe to do right. Painting in lower temperatures seems to have no effect on how the paint worked other than to slow the cure time. Just make sure not to paint below freezing. Try to paint in the cold with a automotive paint and you'll have all kinds of problems
