JaYaYsSoHN
Everything posted by JaYaYsSoHN
  1. so wouldnt u need vented rotors? i think it would be better and easier to use the z31 rear brakes and rotors..
  2. the stock brake master works just fine. alot of 240sx guys use 15/16 masters when they use the z32 calipers same as the skyline calipers so i dont see a problem. why would u use the stock front calipers in the rear? there is really no point.. how would u use your e brake??
  3. hmm.. so if u start it with the key no crank right?? it mught be a igniton relay or for my ZX atleast..
  4. i have an 83zx NA i bought the car in march and everything was working fine until i took off the intake and exhuast manifold then i installed a MSA header and i bought an intake with no EGR and i also bought a JSK Fuel rail then i put everything back together when i try to start the car it wouldnt start i know i am getting spark and i smell fuel so then i took off my fuel rail on the ON position injectors 1-2-3 does not spray any fuel but on injectors 4-5-6 keeps on sparying so i took 4-5-6 injector plugs and mix it around and it also keeps on sparying fuel on any injectors when i plug it. thank u guys in advance oh yeah i also smell alot of fuel in the oil if that helps..also when i unplug injectors 4-5-6 it it takes forever to start and it also back fires in the intake manifold
  5. i have an 83zx NA i bought the car in march and everything was working fine until i took off the intake and exhuast manifold then i installed a MSA header and i bought an intake with no EGR and i also bought a JSK Fuel rail then i put everything back together when i try to start the car it wouldnt start i know i am getting spark and i smell fuel so then i took off my fuel rail on the ON position injectors 1-2-3 does not spray any fuel but on injectors 4-5-6 keeps on sparying so i took 4-5-6 injector plugs and mix it around and it also keeps on sparying fuel on any injectors when i plug it. thank u guys in advance oh yeah i also smell alot of fuel in the oil if that helps..also when i unplug injectors 4-5-6 it it takes forever to start and it also back fires in the intake manifold
  6. hi i have a 83 280zx for some reason my car is not getting any sparks if u can help me it would be greatly appreicated
  7. negative 5 offset moves the tires out of the car
  8. hi i just bought some rims that are 15x7.5 wit -5 offset what are the bigest tires i can put on my 280zx with out it rubbing agianst mah shocks i have bought struts yet but what will fit stock springs and what would fit struts thanks.. and what struts should i get that are adjustable?
  9. goto a junk yard they have alot of dem
  10. i have a 83 280zx i was wonderin if i can stick sum 17x8.5 in front and 17x10.5 int he rear ? and wat off sets? thanks
