                Posts21
Everything posted by WanganDevilZ
	L28 with Rb26 head? Nice! Not exactly digging the back and forth between the two shops, as both produce some beefy motors, but better than my garage none-the-less!
	  L28ET is finally runningWanganDevilZ replied to ComicArtist's topic in S30 Series - 240z, 260z, 280z Not usually, I'm still bumbling around in my FC, I've got my two Zs to worry about till I can get around to one of those, great to see someone with a running S130 Turbo swap in their S30 tho Respect
	Hey guys, I recently got a 1977 280z, crank no start, replaced cap and rotor, spark wires, troubleshot injectors, all 6 are firing, and it does idle now, kind of. This is going to be a direct copy paste from my post on www.zdriver.com (Thread) Just going over routine check, found that all 7 (coil too) spark plug contacts on the rotor cap are rusted, enough that I busted one of the wired trying to get it out even after letting it sit for a while in PB blaster, also the TPS connections are corroded, same with the AFM, let them sit in PB/Toolboxbuddy for a while. Also found out, didn't notice this until today (after hounding this car for about two months) that four of the injectors are black, and two are green. All six of my turbo injectors on the rail, are black. I also remember reading somewhere that N/A = Green, T = Black, correct? I need to take the screws out (as they are stripped, hex screws incoming), to get everything cleaned. All plugs are good, dirty, but they have no concerning flags (Like... coolant..) No other real updates now. Will probably drop the gas tank to fabricate an almost replica from sheet metal/what I find to be safe, as that tank is toast... Sending unit, rest of the tank is identical /break/ Whelp, I went through, checking everything, the plugs were rusted at the dizzy cap (and at the coil too D= ), so I replaced the Cap, wires, and brought over my MSD coil from my S130, cleaned everything, got the broken injector bolt fixed, found out which injectors worked, which didn't (All were firing before I bolted them in, now #1 and #2 are not firing ) But it idles, kinda rough, but its an idle without dieing Also found out that the alternator is shot. So I'll be replacing that with my old one that I have, should still be good. /break/ I think this is my first video proof of one of my Zs running http://www.youtube.com/watch?v=8ZgWGQwgdXM /break/ Found kind of an issue today, the Z will start, idle regularly, but then the RPM will drop and eventually it will die, no matter how much I mess with the idle screw or the TPS http://www.youtube.com/watch?v=5MCR-CkOzs8 /break/ Now, I haven't been able to test the different AFMs I have, I know that the one that was on the car had more pin connections than I actually had on the AFM plug, the AFM I picked up at the salvage yard has the same amount of pins as the plug does, it is from a 79 S130 tho, which... should be okay?
	  L28ET is finally runningWanganDevilZ replied to ComicArtist's topic in S30 Series - 240z, 260z, 280z You ever come to Tulsa for Nismokc meets?
	  wiring guide for installing a rb20det into a datsun ZWanganDevilZ replied to pat1's topic in Nissan RB Forum The wires for the fuel pump are Bl/G, W/B, B, and another color. Now, there is a relay hooked up near the interior fuse box, and there is also one with identical wires near the fusible links box, except it has a yellow wire in addition. Which one is which?
	  wiring guide for installing a rb20det into a datsun ZWanganDevilZ replied to pat1's topic in Nissan RB Forum I know this is a late update, but its really my only day to be working on this with such a nice day outside, and it bein labor day and all, I thought it would be nice to give my Z a few hours labor. The only "Connectors" i have, two are green, one is white, and one is gray/white Pics y0! W/P, W/B, W, Orange First connector is on left. Right connector is B/W, W/B, W/B, and Orange, which is connected to the other connector G/W, W/B, Orange, Cyan Cyan, Cyan Red, Cyan Black, Orange, and Black No 8 pin connectors like you described. D= Edit: I found a gray connector that I had fail spliced a few months ago, it is a round gray connector with an orange inside, its colors are B/W, W, Black, and another black. I must have known something a few months ago because it was connected to my AFM, but it didnt look right... Any help would be extraordinary!
	That is called stealing. Its a very problematic issue on Ebay, and if you bought these from a legitimate company, you can easily get your $27 back. Scan your receipt, take a picture of the USPS box's shipping label, and email it to them, demanding an explanation as to why: 1. They miscalculated and 2. Why you were not reimbursed your $27 immediately when they found out it was not actually going to be 77.50 It may not be a big deal to any of you guys, but thats really low to me. Just my $00.02 Good tidings on your build =)
	  wiring guide for installing a rb20det into a datsun ZWanganDevilZ replied to pat1's topic in Nissan RB Forum where are your grounds at? I'm having trouble finding them, and im sure that's my problem.
	  wiring guide for installing a rb20det into a datsun ZWanganDevilZ replied to pat1's topic in Nissan RB Forum After a bunch of knuckle bruising I think I may be getting it done correctly. Edit: Still failing. Then again I dont know if my ground is grounded. I have the BLU/RED wire on my fuel pump relay (Fuel pump relay on ECU) connected to ECU terminal 18 (Labeled: Fuel pump relay) (BLK/PNK) I also have WHT/BLK on my fuel pump relay connected to the WHT/BLK wire on my ignition, which should be ACC? What is wierd, is that my clock does not turn off. Even with the key removed from the ignition. I also have wire 43 from the RB20 ECU which is ignition switch START signal, and i'm looking at wire 45, which is IGN Ignition switch. Did i kind of do it right? Think you could unscrew your kick panel and take a lookski?
	  wiring guide for installing a rb20det into a datsun ZWanganDevilZ replied to pat1's topic in Nissan RB Forum Is it absolutely necessary to use a 30amp? What would happen if i used the current relay on my Z? Edit: Also, did you use your stock engine bay fuse box or the RB20 fuse box?
	  wiring guide for installing a rb20det into a datsun ZWanganDevilZ replied to pat1's topic in Nissan RB Forum +100 to appreciation, but I'm a little bit confused, could you provide pictures of the said steps? I've been sitting in my driveway scratching my head all afternoon, it took me a while to find the FP relay, and now I dont know what to do with it xD!
	Nvm, i just noticed on the albums that its an Automatic tranny mount. My mistake xD Also, for some reason i was not able to edit my post above... any reason why?
	None taken. I just hope nothing leaks. I'll try and get a solid pipe welded/built soon, and don't plan on running it very much/hard until i can find out that it does in fact hold, till i can get the metal pipe done.
	The finished product:
	Nvm, thank you Lowes
	I am running a left hand drive 280zx, and trying to mount my RB20det. I have almost everything done, except the oil return from the turbo. My problem is, i can not drop the engine in 100% without the return hose resting on my steering column, which in turn, will wear down in no time unless i do something. Has anyone run into this? I cant find anything, and the last thing i want to do is pull the oil pan off to make a new inlet from the turbo.. but that seems like my only option. Anyone else with LHD?
	Depends on where you get all your components from. It also depends if you put the motor in yourself. For the 26, easily looking at 10k+ I have a 20, and i've already spend about 3k, including the motor, but the 20 pretty much drops right in to the 280zx.
	I know that this thread is ANCIENT, but i have somewhat of a problem regarding the stock tranny mount... Reading this thread gave me the get-up-and-go to go finish my ZX, and i did, i got the motor in, however, my tranny wont bolt up, by a good inch, or half inch if i'm lucky... Is the 81ZX different from the 82ZX? And I have a 1+1 Is there something I did wrong?
	20, planning on upgrading to the 25 soon I went with the 20, cause it was a decent motor from what i read. I had planned on getting a 2jzTT, but the feedback on how much of a hassle it was to swap into the Z made me change my mind.
	Anyone have any idea if the 280zx 2-Seater driveshaft fits nicely? I measured from the engine mounts to the end of the transmission, and they seem to be about the same length give or take less than 10mm... Will be finding out for myself here in a few weeks >.<
