Kbhead
About Kbhead
  • Birthday 07/30/1970
  • Gender
    Male
  • Location
    Victoria, BC
  • Interests
    Cars
Recent Profile Visitors
Kbhead's Achievements
Newbie
  • Dedicated Rare
  • Conversation Starter Rare
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
10
  1. Hello, Replacing my stock fan with a Honda Civic fan one. So far not working but I have a red wire (shown in picture) that I can not find a location to plug back into. It wasn't plugged into anything when I took it apart. Could be the reason why my stock fan wasn't working in the first place along with the heater assembly lights. The map light works as it is connect to different wiring harness. Is this red wire used for power and if so where does it plug into, I can't seem to find it's partner unless it is a blue wire, if so which one? Any help would be appreciated. Thank you,
  2. Very impressive, I wasn't sure how it would all come together, looks great!
  3. Hello, Can anyone tell me where the Blue and Green wires go to? I'm assuming both can go to +12v when ignition is turned on. thanks
  4. Hello, reading through your post, I didn't see an answer to your question. I think the green wire goes to +12 volt when ignition is on? But where does the blue wire go? Thank you,
  5. Wow, that's creative. Cool idea, look forward to the end result. Keep the pictures coming!
  6. Re: "Cooling fluid". I was working from old information when installing my Koni's. You bring up a good point, always refer to Manufactures recommendations. Struts spec'ed. Let me clarify, my intent was just to point out that 280Z struts and 240Z struts have a different diameter size, et alone the difference in lenght. OEM Shocks may have different diameter size than what you might get from a third party manufacture. So, when sectioning your struts, note a shock for a 280Z might not work for a 240Z strut due to the different in the diameter size.
  7. 280Z struts are longer and wider than the 240Z struts. Which means you can use a 240Z (30 mm) shock in a 280Z strut (if you have shortened the struts) but you can not use a 280Z (36 mm) shock in a 240Z strut (diameter is too small and no room for outside cooling fluid in the strut. Some people put 280Z struts on their 240Z, to take advantage of the size difference which give them more shocks options. Advantage to the larger diameter shocks is; more fluids in the shock for pressure adjustments up and down and heat resistance.
  8. Good point, I forgot about that. Thinking more about this and reading the comments maybe the best idea would be to start another thread (do not want to take away from this thread) and get a list of Wheel manufactures that make custom wheels (offsets, sizes and lug combinations). Thanks to Nelsonian for listing a few: Boosted300, Great thread. What size wheels and tires do you have on the front? (sorry if you have already mentioned it, I can seem to find it when looking back).
  9. Hello Boosted300, Is it possible to take measurements backed by pictures of the inside if your rim the next time you take your wheels off, then post it. Not that I don't trust the calculations, it's just seams easier and final. I think the +17 mm is accurate. 2nd, Does anyone have access to a vendor that would be interested in making wheels with this offset for a group buy, with a matching pair for the front? I would be very interested in a set 17" or 16". First choice would be Volk Racing TE37VE , 2nd ROTA. thx
  10. Hello, I have found a Voltage/Fuel Gauge, thank you for all the responses. The wanted ad can be removed or closed. K
  11. Hello, I'm looking for a 77-78 280Z Voltage/Fuel Gauge in working condition. If anyone has an old one that they do not want anymore, please email me with a pic and how much you want for your gauge. Thank you, K
  12. Well I couldn't find a used harness that I was missing, found a wiring kit that someone posted in another discussion, see the link below: E40 J1 Harness Assembly for 2005-06 GTO ECM http://www.eficonnection.com/eficonnection/ItemDetails.aspx?ItemId=848 Not sure if anyone has used this "Stand-a-lone Fuse/Relay Module", looks like it might do the trick for your fuel pump, fan, starter and ac. http://www.currentperformance.com/Accessories/wiring_acc.html
  13. Excellent job! Really appreciate all the pictures, helps understand how your doing things.
  14. I am looking for the wiring harness that comes out from the EMC(C1)or J1 connector to the Accelerator Pedal Position Sensor. I seem to only have the two harnesses that come out from the ECM(C2,C3).
