Search the Community
Showing results for tags 'Stub Axle'.
	We just started selling these CNC re-drilled rear stub axles. These rear stub axles come with a 5x114.3 and 4x114.3 bolt pattern. This will allow you to use 5 lug wheels on your S30. Many popular cars like the 240sx, 300zx and 350z have the 5x114.3 bolt pattern. You will need to get your own wheel studs. They are stock 27 spline 280Z stub axles with 280z companion flanges. They will work with any 240Z 260Z and 280Z axle. The 240z does not have the same spine count as the 280z but since these come with the companion flange they will bolt into your stock 240z axle. Price is $300 plus you send us your original stub axles and companion flanges as cores or $450 without cores TO ORDER GO TO OUR WEBSITE: http://www.silverminemotors.com/datsun/datsun-240z/suspension/5-lug-hub-stub-axles-for-240z-260z-280z Let me know if you have any other questions.
	Ok, so I can see the finish line from a very long journey, that is my 1973 RB 240Z. I have a CLSD from an 1989 Z31T with the CV shafts. I'm trying to get the CV axles bolted into my car but I have been finding out that these adapter options for the CV adapter conversion are PRICEY!!! Especially, when you factor in the price for having to get the 27 spline axles from a 280Z (getting harder to find) and the Modern-Motorsport option. Plus, I don't know why NOBODY developed and adapter for the stock 240Z 25 spline stub axles to just bolt to the Z31T CV axles!!!! People keep saying that it was for strength but I don't buy that. They are not much thicker, and you've only gained just 2 splines. For a stock RB, I'm sure the 25 spline will hold up just fine. I'm just trying to get my CV's under the car. Looking for the welded plate to stock flange option so that I can get my car back on the road. I've seen pictures on Google from what Modern-Motorsports "used" to do, but I need better specs for the plate(steal). I found specs for a plate for the 280ZXT CV's, but I cant figure out why no one has done this for the Z31T CV axles. Maybe I'm looking in the wrong place... Anyone have any answers??? Thanks for any and all help you give.
