Search the Community
Showing results for tags 'bmw engine'.
I thought I share my Datsun project here. I bought it about year ago from US. I looked car that was not too rusted, was running and cost under 5K. Finally found this -71 240Z from Hollywood. It was little over my budget, but seller was kind enough to drive it so shipping company, so I saved few hundred in there. And there was also lots of new parts included. Car had L28, 5 speed, R200 and Z31 ECU. After waiting two (long) months car finally arrived to Finland and it turned out to be in much better condition that I could never expect. There was almost no rust and car really was in driving condition. I drove few days with it and then teared it apart. And I also sanded it to bare metal. Only welding that I did was fill those side light holes because they are not needed in my country. After that it was time to paint. Painting was done in my own garage where I did small "paint booth". After painting it needed lots and lots of wet sanding and polishing... Previous owner had fitter Eibach springs and Tocico shocks but I wanted it to be lower so coilovers were needed. I bought BC Racing coilovers that were meant for S13 and fitted them to S30. I cutted original shock tubes and welded threaded collars in place of them. S13 camper adjust strut tops were too big for S30 strut towers, so I made smaller strut tops. There is not much camper adjust, but at least some. Previous owner had fit disk brakes to rear and 13/16" MC. I decided to upgrade front brakes with 300mm vented rotors and Outlaw calipers. I also did 5-lug swap using Z31 parts in front and rear hub was redrilled. I have always liked old BBS wheels and bought BBS RM. Wheel were originally 7.5" x 15" and rear wheels were widened 1.25". Interior was in quite bad shape. Seat cover was broked and dash was cracked. I repaired dash with fiber glass and painted it black. Seat was repaired with new covers. New gauges came from Speedhut. I have now driven about 5000km with my Datsun in this summer. Have been in few track days and few car meets. And it has worked perfectly. As for new engine I wanted some modern 6 cyl engine, and though RB25. However those are quite expensive and rare in our country, so I used something totally different...BMW M50B25 with 5 speed ZF310 gearbox. I used 2.8 crankshaft and pistons so engine is now 2.8 instead original 2.5. Also block height is shaved 2mm to get squish height to about 1mm. That shaving also get me 12:1 compression so I am going to use E85. As engine management I am using Megasquirt MS3. And I also have M3 throttle bodies and headers and some hotter cams. Engine is now totally rebuild with new piston rings, bearings, cam chain, etc. During this winter I need to get this engine fitted to Datsun engine compartment and get everything working.
- 77 replies
- 1
- bc-racing coilovers
- m50b25
(and 3 more)
Tagged with:
