Search the Community
Showing results for tags 'fuel hose'.
Hello All, I had a frightening moment with my '77 280Z after replacing old fuel hoses. I started it up and one of the injectors with the factory crimped hoses tore and started spraying fuel down on my headers. Luckily there was no fire and I had an extinguisher in hand. What has me really disturbed about this is that I purchased these injectors last year and they've only been running on the car for a total of maybe 2 hours at most. My fuel pressure doesn't exceed 40psi (have a mounted gauge). I replaced the hose on this injector, which is described in other threads on this topic. I don't have a concern with replacing the other 5 injector hoses, but I would rather trust that the manufacturer of the injectors knew what they were doing and there's something I should be aware of to prevent risk of a future fire. The tear happened just below the hose clamp (flat banded clamp). The clamp was pretty tight but didn't seem extreme. When looking at the 5 remaining hoses, they appear to get skinny in the middle like they're under serious vacuum. The outsides look in perfect shape but I'm a little concerned with the shape is all. I purchased all injectors at the same time so I can assume I would experience this issue at any point with the others. Has anyone else had a similar experience to this? I would typically replace and test on most things but I don't want to repeat my last experience. Thanks
