I generally keep my car in the garage in the winter. So far, it has only had the occasional struggle starting when left out in the cold. However, this last weekend it was down to -37C, and I was over at a friend's place now it's Tuesday, -10C, and it still wont start (cranks but no firing at all).
I have heated it well beyond what it should need to start (using several devices). with no luck. I have found the following, the pump still works, there is spark, it cranks just fine, and it won't start even when jumped. It runs and starts just fine above +5C (with no external heater).
There is a possibility the fuel lines have frozen but that seems unlikely, and I have no way to test compression, but I hear that is another possibility.
Does anyone have ideas or suggestions?
