Search the Community
Showing results for tags 'shock removal'.
	Hi All, I did a very not-so-smart thing and over torqued the shock nut (top nut going into the insulator) when installing my Koni Yellow shocks into the rear strut tubes. Does anybody know how to free this nut without damaging the shock? In the pictures it is clear how far down the nut is based on the number of threads showing. I believe the nut has gone so far down that it is past the normal shock threads and is "threading" into the non-threaded part of the shock. It is impossible to fit a wrench around the smaller hex end just below the adjustment knob of the shock while also using a larger wrench to loosen the shock nut due to the height of the insulator surrounding it (and yes, despite the pictures being taking when installed, I have taken the strut assembly off the car). I am tempted to use a thick mouse pad to wrap around the shock tube itself and hold it still with vice grips while I loosen the nut but I'm anxious to do so. If anyone has any recommendations or has dealt with this before I would greatly appreciate your help. Thanks, Liam
- 5 replies
		- shock removal
- shock absorber
					(and 1 more)
					Tagged with:
