Hartspank Posted June 5, 2011 Share Posted June 5, 2011 (edited) Hey guys, the check engine light came on in my '88 turbo today. i can't find the diagnostic link for the life of me! The owners manual says to pull the ecu and count the flashing lights. Is that right? How do you get the light off? It runs fine... It is bone stock. Thanks Jason Edited June 5, 2011 by Hartspank Quote Link to comment Share on other sites More sharing options...
Hartspank Posted July 2, 2011 Author Share Posted July 2, 2011 Bueller...... Quote Link to comment Share on other sites More sharing options...
Domzs Posted July 5, 2011 Share Posted July 5, 2011 On 7/2/2011 at 10:48 PM, Hartspank said: Bueller...... you are correct . that is how you get DTC for your car . they are 5 modes , make sure you check them all . Quote Link to comment Share on other sites More sharing options...
michaelp Posted July 22, 2011 Share Posted July 22, 2011 You're lucky...88-89s have a CONSULT connector in the passenger kick panel by the ECU to do an auto code check. The other option is turning the screw on the ECU and watching the lights flash. You do NOT have to do all 5... http://xenonz31.com/ECUcodes.html Keep in mind the diagnostic connector is NISSAN CONSULT, meaning you'll need a consult adaptor and software for whatever scan tool you're using. Also, CEL is Cali emissions only. If you look in the FSM it'll note the few things that are check engine light worthy. Its likely Injector Leak, EGT, or EGR. http://xenonz31.com/reference.html Quote Link to comment Share on other sites More sharing options...
