tsabboi Posted June 10, 2011 Share Posted June 10, 2011 I'm in the process of installing my slave cylinder onto the clutch housing... but I cannot figure out what bolt I should use since the replacement didn't come with one... does anyone have these bolt info because the service manual only tells me the torque specification (22 to 30 lbs) but not the exact bolt size. i have searched most of Google on, "replacement bolts, slave cylinder bolts" and havent came up with anything... thanks in advance! Quote Link to comment Share on other sites More sharing options...
tsabboi Posted June 15, 2011 Author Share Posted June 15, 2011 Please if any of you guys/girls know the specifications it would help me a lot... no luck on google... Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 15, 2011 Share Posted June 15, 2011 I know that it has a 14mm head on it. I believe it's the same thread as a transmission or starter mounting bolt. Remove a similar bolt (a transmission bolt should be right there close to the hole), try it in the hole and guess the depth. Quote Link to comment Share on other sites More sharing options...
tsabboi Posted June 16, 2011 Author Share Posted June 16, 2011 I know that it has a 14mm head on it. I believe it's the same thread as a transmission or starter mounting bolt. Remove a similar bolt (a transmission bolt should be right there close to the hole), try it in the hole and guess the depth. thanks very much Quote Link to comment Share on other sites More sharing options...
KiwiCowboy Posted July 3, 2011 Share Posted July 3, 2011 The bolts are 10-1.5 x 25mm Hex bolts Quote Link to comment Share on other sites More sharing options...
