voltron_boi Posted June 15, 2011 Author Share Posted June 15, 2011 After removing the head this is what I found. Valve damage the piston Now i know forsure that i will be needing a new exhaust valve. I was just carious is the piston still useable or is it trash? Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted June 16, 2011 Author Share Posted June 16, 2011 This is what happend to the head. Do you guys think the head is still rebuildble also. Probably gonna change the piston, and have the machine shop check the valves. Quote Link to comment Share on other sites More sharing options...
pat1 Posted June 16, 2011 Share Posted June 16, 2011 (edited) Man,I hate to say this but it's trashed. Turn the motor over and inspect the cylinder walls. The head is trashed, I bet the valve guide is busted also. I would take it to a machine shop and get them to inspect the head. The piston is hard to say, I've seen worse and I was able to grind off the ridges on the impact zone. It's possible that the piston might cracked.Inspect it and go from there. Inspect the other valves because if you hit one you might of hit more. Edited June 16, 2011 by pat1 Quote Link to comment Share on other sites More sharing options...
jakeoster Posted June 16, 2011 Share Posted June 16, 2011 RAW Brokerage sells RB25 long blocks. I'd think you'd be way better off going that route. Sorry to see this man, that really really sucks. Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted June 16, 2011 Author Share Posted June 16, 2011 Man,I hate to say this but it's trashed. Turn the motor over and inspect the cylinder walls. The head is trashed, I bet the valve guide is busted also. I would take it to a machine shop and get them to inspect the head. The piston is hard to say, I've seen worse and I was able to grind off the ridges on the impact zone. It's possible that the piston might cracked.Inspect it and go from there. Inspect the other valves because if you hit one you might of hit more. Yeah, I suspecting the head is trashed, but I dont no that for-sure until I drop it off at the machine shop tomorrow. I check the cylinder walls and it look to be normal all around 6 cylinder. I'm going to replace the piston as soon as I find another good piston, because I dont want to risk anything in the future. Quote Link to comment Share on other sites More sharing options...
sileightygx Posted June 16, 2011 Share Posted June 16, 2011 sorry to see that happen man. you are going the better route by replacing the piston anyway. would suck if you rebuilt and put back together, only to have piston crack 2k miles or so down the road. Quote Link to comment Share on other sites More sharing options...
