Comments required for AFR target table
2s2mad
Hi Guys,
Here is my setup:
Ported and polished N42 head with stage 1 Isky cam, on stock rebuilt block (1978 280Z)
Stock injectors
240SX TPS
MS2 V3 board (ExtraEFI), TunerStudioMS software v1.0004, FUEL Only.
Aftermarket FPR: 42 PSI
AEM Wideband gauge and bosch sensor.
Custom inox header and complete exhaust (3 inches)
The car is currently up and running (daily driver)
I am using the VE Analyze Live to correct my Fuel VE Table in TunerStudio.
Could I have your comments on my target AFR map.
Are there any crazy things I should correct?
My car is running pretty good once it reaches operating temp.
I get some lean pops out of the exhaust when I decelerate but nothing too loud (afr between 13.5 and 14 when it pops)
I am not using any TPS enrichment.
Thanks for your time.
Simon
2011-06-27_19.28.43.zipFetching info...
2s2Mad, our AFR tables were very similar. My car is NA with a stage III cam.
A couple of days ago I evened the table out some by lowering the cruise area from 14.7 to 14.0 and bumping up the the high rpm areas a bit.
Best tune I have run to date.
Edited by tennesseejed
