J240ZTurbo Posted July 23, 2011 Share Posted July 23, 2011 (edited) Ok guys I need help I got a 240zt with megasquirt with a built in harness by a good friend of mine all is new. I had someome here set in up my MS2 but after many cranks we notice that I got no spark, rpm nor any pulse in my set up so the car wont start. I do know I dont have the fancy pin in there in section Q16 so it will spark, but thats why Im using the original ignater from the 280zxt coil, please any help will be awesome. I also got a copy of my MSQ FILE. <?xml version="1.0" encoding="ISO-8859-1"?> <msq xmlns="http://www.msefi.com/:msq"> <bibliography author="TunerStudio 0.999.7 - Phil Tobin - p_tobin@yahoo.com" writeDate="Fri Jul 22 20:46:46 EDT 2011"/> <versionInfo fileFormat="4.0" nPages="2" signature="MSII Rev 2.88600 "/> <page number="0" size="994"> <constant name="taeColdM" units="%">130.0</constant> <constant name="triggerOffset" units="deg">-5.0</constant> <constant name="egoRPM" units="RPM">1300.0</constant> <constant name="AFRStoich" units="AFR">4.5</constant> <constant name="tempUnits">"Coolant/IAT Tables in °F"</constant> <constant name="dwellAcc" units="msec">0.6</constant> <constant name="baro0" units="kPa">9.3</constant> <constant cols="1" name="fuelFreq" rows="2" units="Hz"> 50.0 150.0 </constant> <constant name="IdleHyst" units="°F">5.0</constant> <constant name="tpsMin" units="ADC">160.0</constant> <constant name="Delay_Teeth" units="teeth">0.0</constant> <constant cols="1" name="knk_rpm" rows="6" units="rpm"> 500.0 1000.0 2000.0 3000.0 4000.0 5000.0 </constant> <constant name="taeColdA" units="msec">3.0</constant> <constant name="egoType">"Narrow Band"</constant> <constant name="alternate">"Alternating"</constant> <constant name="crankCold" units="msec">11.0</constant> <constant name="cltmult" units="%">100.0</constant> <constant name="knkDirection">"Below threshold"</constant> <constant name="bcormult" units="%">-47.0</constant> <constant name="knk_tadv" units="sec">2.0</constant> <constant cols="1" name="fuelSpkDel" rows="2" units="deg"> 0.0 -13.0 </constant> <constant name="crankingRPM" units="RPM">300.0</constant> <constant name="egoTemp" units="°F">280.0</constant> <constant name="MAPOXLimit" units="kPa">90.0</constant> <constant name="egoTarget" units="v">0.45</constant> <constant name="asePctHot" units="%">25.0</constant> <constant name="AMCve_rpm" units="RPM">200.0</constant> <constant name="board_type">1.0</constant> <constant name="primePulseCold" units="msec">6.0</constant> <constant name="ASEHot">"Enable ASE on Hot Start"</constant> <constant name="InjStart" units="%">0.0</constant> <constant name="max_spk_dur" units="msec">2.0</constant> <constant name="knk_dtble_adv" units="deg">3.0</constant> <constant name="No_Miss_Teeth" units="teeth">2.0</constant> <constant cols="1" name="maeBins" rows="4" units="msec"> 0.0 0.0 0.0 0.0 </constant> <constant cols="1" name="srpm_table" rows="12" units="RPM"> 500.0 1000.0 2000.0 3000.0 3500.0 4000.0 4500.0 5000.0 5500.0 6000.0 6500.0 7000.0 </constant> <constant name="beta" units="%">80.0</constant> <constant cols="1" name="psPortValue" rows="7"> 0.0 0.0 0.0 1.0 0.0 0.0 1.0 </constant> <constant name="flexFuel">"Disabled"</constant> <constant name="gamma" units="%">10.0</constant> <constant name="pwImpulse" units="msec">0.0</constant> <constant cols="1" name="psEnabled" rows="7" units="on/off"> 0.0 0.0 0.0 1.0 0.0 0.0 1.0 </constant> <constant name="ICCrankTrigger">"Calculated"</constant> <constant cols="1" name="taeBins" rows="4" units="msec"> 1.0 2.5 3.5 5.5 </constant> <constant name="mapdotSample" units="msec">25.0</constant> <constant name="CWOption">"Two-Point"</constant> <constant name="Dtpred_Gain" units="%">0.0</constant> <constant name="AMCramve_dt" units="sec">20.0</constant> <constant cols="1" name="maeRates" rows="4" units="kPa/sec"> 0.0 0.0 0.0 0.0 </constant> <constant name="egoCount">16.0</constant> <constant name="knkOption">"Disabled"</constant> <constant name="fastIdleT" units="°F">140.0</constant> <constant name="tpsLF">75.0</constant> <constant name="ego0" units="afr">0.0</constant> <constant name="mapLF">50.0</constant> <constant name="IACcrankxt" units="sec">5.0</constant> <constant cols="12" name="afrTable1" rows="12" units="AFR"> 13.0 13.5 16.0 16.0 16.0 14.9 14.3 13.2 13.1 13.2 13.1 13.0 13.2 13.7 15.7 15.7 15.5 14.9 14.2 13.2 13.0 12.9 12.8 12.7 13.4 13.9 15.5 15.5 15.4 14.9 14.1 13.0 12.9 12.8 12.7 12.7 13.5 14.0 15.2 15.2 15.0 14.7 14.0 13.0 12.9 12.8 12.7 12.6 13.6 15.0 15.0 14.9 14.7 14.7 14.0 12.9 12.8 12.7 12.6 12.6 13.5 15.0 15.6 14.3 14.1 14.1 13.5 12.8 12.7 12.6 12.6 12.6 13.4 15.0 15.0 13.7 13.6 13.6 13.1 12.7 12.6 12.6 12.6 12.6 13.2 13.2 13.5 13.3 13.3 13.2 13.0 12.6 12.5 12.5 12.5 12.5 13.0 13.0 13.1 13.0 13.0 12.9 13.0 12.5 12.5 12.5 12.5 12.5 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.5 12.4 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.3 12.3 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.2 12.2 12.2 </constant> <constant name="ae_lorpm" units="rpm">2500.0</constant> <constant cols="12" name="afrTable2" rows="12" units="AFR"> 13.0 13.5 16.0 16.0 16.0 14.9 14.3 13.2 13.1 13.2 13.1 13.0 13.2 13.7 15.7 15.7 15.5 14.9 14.2 13.2 13.0 12.9 12.8 12.7 13.4 13.9 15.5 15.5 15.4 14.9 14.1 13.0 12.9 12.8 12.7 12.7 13.5 14.0 15.2 15.2 15.0 14.7 14.0 13.0 12.9 12.8 12.7 12.6 13.6 14.1 15.0 14.9 14.7 14.7 14.0 12.9 12.8 12.7 12.6 12.6 13.5 13.8 14.5 14.3 14.1 14.1 13.5 12.8 12.7 12.6 12.6 12.6 13.4 13.4 13.9 13.7 13.6 13.6 13.1 12.7 12.6 12.6 12.6 12.6 13.2 13.2 13.5 13.3 13.3 13.2 13.0 12.6 12.5 12.5 12.5 12.5 13.0 13.0 13.1 13.0 13.0 12.9 13.0 12.5 12.5 12.5 12.5 12.5 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.5 12.4 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.3 12.3 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.2 12.2 12.2 </constant> <constant cols="1" name="dwellDuration" rows="5" units="msec"> 2.4 0.9 0.0 -0.5 -0.9 </constant> <constant name="an_direction">"Blend SD (hi_rpm)/Alpha-N (lo_rpm)"</constant> <constant name="aseCountHot" units="cycles">150.0</constant> <constant name="egoAlgorithm">"Transport Delay"</constant> <constant name="ICISR_pmask" units="%">50.0</constant> <constant name="dualTable">"Single Table"</constant> <constant name="acc_synchk">"Check Always"</constant> <constant name="floodClear" units="%">70.0</constant> <constant name="fuelFreq0" units="Hz">50.0</constant> <constant name="fuelFreq1" units="Hz">150.0</constant> <constant name="aseCountCold" units="cycles">350.0</constant> <constant name="fuelSpkDel0" units="deg">0.0</constant> <constant name="knockmax" units="V">5.0</constant> <constant name="fuelSpkDel1" units="deg">-13.0</constant> <constant name="tpsdotSample" units="msec">25.0</constant> <constant cols="1" name="ipwmTable" rows="10" units="%"> 40.0 60.0 75.0 90.0 105.0 120.0 130.0 140.0 150.0 160.0 </constant> <constant name="ECUType" units="1=MS-II, 2=MicroSquirt">1.0</constant> <constant name="impulseSec" units="sec">0.0</constant> <constant name="tpsThresh" units="%/sec">200.0</constant> <constant name="injTestPW" units="msec">20.0</constant> <constant name="reqFuel" units="msec">6.3</constant> <constant name="IACpwm_step" units="Hz">80.0</constant> <constant name="tpsProportion" units="%">100.0</constant> <constant name="nCylinders">"6"</constant> <constant cols="1" name="knk_thresh" rows="6" units="v"> 2.0 2.0 2.0 2.0 2.0 2.0 </constant> <constant name="CID" units="cu.in.">160.0</constant> <constant name="knk_maxrtd" units="deg">10.0</constant> <constant name="battmax" units="V">29.7</constant> <constant name="MapThreshXTD2" units="-kpa/sec">60.0</constant> <constant name="alpha" units="%">90.0</constant> <constant name="mycan_id">0.0</constant> <constant name="IACaccstep" units="msec">0.0</constant> <constant name="knock0" units="V">0.0</constant> <constant name="MAFpin">"MAF on MAP pin"</constant> <constant name="RevLimOption">"Fuel Cut"</constant> <constant cols="7" name="psHysteresis" rows="2"> 0.0 0.0 0.0 50.0 0.0 0.0 30.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="AMCstep" units="%">10.0</constant> <constant name="crankTolerance" units="%">50.0</constant> <constant cols="1" name="frpm_table" rows="12" units="RPM"> 1000.0 2000.0 2500.0 3000.0 3500.0 4000.0 4500.0 5000.0 5500.0 6000.0 6500.0 7000.0 </constant> <constant name="AFRStoichNB" units="Volts">0.45</constant> <constant name="fet_delay" units="µsec">0.0</constant> <constant name="asTolerance" units="%">70.0</constant> <constant name="rpmLF">50.0</constant> <constant name="AfrAlpha">0.0</constant> <constant name="knk_lorpm" units="rpm">700.0</constant> <constant name="injTestOffTime" units="msec">60.0</constant> <constant name="prime_delay" units="sec">0.0</constant> <constant cols="1" name="amap_rpm" rows="6" units="RPM"> 0.0 500.0 1000.0 1500.0 2000.0 2000.0 </constant> <constant cols="1" name="wueBins" rows="10" units="%"> 180.0 180.0 160.0 130.0 120.0 112.0 108.0 102.0 102.0 100.0 </constant> <constant name="spkout_hi_lo">"Going High (Inverted)"</constant> <constant name="primePulseHot" units="msec">2.0</constant> <constant name="alpha_hirpm" units="RPM">0.0</constant> <constant name="knkLF">80.0</constant> <constant name="RevLimMaxRtd" units="deg">12.0</constant> <constant name="AFRMult">"Separate VE & AFR table w/ NB EGO"</constant> <constant cols="1" name="fmap_table" rows="12" units="kPa"> 30.0 35.0 45.0 50.0 55.0 60.0 70.0 75.0 80.0 85.0 95.0 100.0 </constant> <constant name="AFRStoichWB" units="AFR">4.5</constant> <constant name="OddAng" units="degrees">0.0</constant> <constant name="egoDelta" units="%">1.0</constant> <constant name="egoKI" units="%">20.0</constant> <constant name="divider">3.0</constant> <constant name="egoKD" units="%">0.0</constant> <constant cols="1" name="psInitValue" rows="7"> 0.0 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="matmult" units="%">100.0</constant> <constant name="AMCOption">"Disabled"</constant> <constant name="tpsMax" units="ADC">829.0</constant> <constant name="knk_ndet" units="knocks">2.0</constant> <constant name="bcor0" units="%">147.0</constant> <constant name="adcLF">50.0</constant> <constant name="map0" units="kPa">9.3</constant> <constant name="egomult" units="%">100.0</constant> <constant name="egoKP" units="%">100.0</constant> <constant name="AMCdve" units="%">2.0</constant> <constant name="asePctCold" units="%">45.0</constant> <constant name="egoKdelay2" units="revs">4000.0</constant> <constant name="egoKdelay1" units="msec">10.0</constant> <constant name="DualSpkOptn">"No Dual Spark"</constant> <constant cols="1" name="taeRates" rows="4" units="%/sec"> 100.0 300.0 600.0 900.0 </constant> <constant name="PredOpt">"Last Interval"</constant> <constant name="MapThreshXTD" units="-kpa/sec">40.0</constant> <constant name="egoLF">60.0</constant> <constant name="tdePct">90.0</constant> <constant name="algorithm">"Speed Density"</constant> <constant name="IACcoldpos" units="steps">120.0</constant> <constant cols="1" name="iacstepTable" rows="10" units="steps"> 40.0 60.0 75.0 90.0 105.0 120.0 130.0 140.0 150.0 160.0 </constant> <constant name="aeEndPW" units="msec">2.0</constant> <constant cols="1" name="fuelCorr" rows="2" units="%"> 100.0 163.0 </constant> <constant name="mapmax" units="kPa">260.9</constant> <constant name="MapThreshXTA" units="kpa/sec">35.0</constant> <constant name="taeTime" units="sec">0.2</constant> <constant name="nImpulse">0.0</constant> <constant cols="1" name="dwellVolts" rows="5" units="V"> -4.0 -2.0 0.0 2.0 4.0 </constant> <constant name="knk_hirpm" units="rpm">3500.0</constant> <constant name="AMCve_map" units="kPa">10.0</constant> <constant name="knk_maxmap" units="kPa">70.0</constant> <constant name="batt0" units="V">0.1</constant> <constant name="knk_trtd" units="sec">0.2</constant> <constant name="ICIgnOption">"Standard Coil Charge"</constant> <constant name="TPSOXLimit" units="%">70.0</constant> <constant name="baromax" units="kPa">260.9</constant> <constant name="battFac" units="ms/v">0.2000004</constant> <constant name="IgnAlpha">0.0</constant> <constant name="trendmapLimit" units="kpa">5.0</constant> <constant name="IACStart">160.0</constant> <constant name="nInjectors">"6"</constant> <constant name="no_skip_pulses">3.0</constant> <constant name="injType">"Port Injection"</constant> <constant name="ICISR_tmask" units="msec">0.0</constant> <constant name="max_coil_dur" units="msec">3.1</constant> <constant name="IdleCtl">"15-Minute IAC"</constant> <constant name="pulseTolerance" units="%">25.0</constant> <constant name="injTestMode">"Normal Mode"</constant> <constant name="injTestSqrts" units="squirts">400.0</constant> <constant cols="1" name="psConnector" rows="7"> 32.0 32.0 32.0 32.0 32.0 32.0 32.0 </constant> <constant name="AMCupdate_thresh" units="events">2.0</constant> <constant name="injOpen" units="msec">1.0</constant> <constant name="IACcoldtmp" units="°F">0.0</constant> <constant name="IACminstep" units="steps">1.0</constant> <constant name="AMCT_thresh" units="sec">1800.0</constant> <constant name="No_Skip_Teeth" units="teeth">9.0</constant> <constant cols="1" name="smap_table" rows="12" units="kPa"> 35.0 40.0 50.0 60.0 70.0 75.0 80.0 85.0 90.0 95.0 98.0 100.0 </constant> <constant name="alpha_lorpm" units="RPM">0.0</constant> <constant name="vr_delay" units="µsec/1000rpm">0.0</constant> <constant name="MAFOption">"No MAF"</constant> <constant cols="1" name="tempTable" rows="10" units="°F"> -40.0 -20.0 0.0 20.0 40.0 60.0 80.0 100.0 130.0 160.0 </constant> <constant name="mapThresh" units="kPa/sec">100.0</constant> <constant name="clt0" units="°F">0.0</constant> <constant name="twoStroke">"Four-stroke"</constant> <constant name="fuelCorr0" units="%">100.0</constant> <constant name="fuelCorr1" units="%">163.0</constant> <constant name="IACcoldxt" units="sec">40.0</constant> <constant name="mat0" units="°F">0.0</constant> <constant name="baud">115200.0</constant> <constant cols="7" name="psOutSize" rows="2"> 0.0 0.0 0.0 2.0 0.0 0.0 2.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="ae_hirpm" units="rpm">5000.0</constant> <constant name="injPwmPd" units="µsec">66.0</constant> <constant name="ICIgnCapture">"Rising Edge"</constant> <constant cols="7" name="psCondition" rows="2"> 60.0 60.0 60.0 62.0 60.0 60.0 62.0 60.0 60.0 60.0 60.0 60.0 60.0 60.0 </constant> <constant cols="7" name="psOutOffset" rows="2"> 1.0 1.0 1.0 22.0 1.0 1.0 22.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 </constant> <constant name="baroCorr">"Initial MAP Reading"</constant> <constant name="IACcrankpos" units="steps">100.0</constant> <constant name="injPwmP" units="%">30.0</constant> <constant cols="7" name="psThreshold" rows="2"> 0.0 0.0 0.0 1900.0 0.0 0.0 1970.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="crankHot" units="msec">3.0</constant> <constant name="aeTaperTime" units="sec">0.1</constant> <constant name="triggerTeeth" units="teeth">0.0</constant> <constant cols="6" name="alphaMAPtable" rows="6" units="kPa"> 100.0 60.0 30.0 35.0 40.0 40.0 100.0 65.0 35.0 40.0 45.0 45.0 100.0 70.0 40.0 45.0 50.0 50.0 100.0 75.0 45.0 50.0 55.0 55.0 100.0 80.0 50.0 55.0 60.0 60.0 100.0 80.0 50.0 55.0 60.0 60.0 </constant> <constant name="RevLimRpm2" units="RPM">7000.0</constant> <constant cols="1" name="amap_tps" rows="6" units="%"> 0.0 12.0 16.0 30.0 60.0 60.0 </constant> <constant name="RevLimRpm1" units="RPM">6800.0</constant> <constant cols="1" name="cold_adv_table" rows="10" units="deg"> 6.0 5.0 4.0 3.0 2.0 1.0 0.0 0.0 0.0 0.0 </constant> <constant name="egoLimit" units="%">15.0</constant> <constant name="IACtstep" units="msec">2.5</constant> <constant name="knk_step2" units="deg">1.0</constant> <constant name="injPwmT" units="msec">1.5</constant> <constant name="knk_step1" units="deg">3.0</constant> </page> <page number="1" size="946"> <constant cols="1" name="matCorrDelta" rows="6" units="%"> 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="VEIXOptn">"Use MAP only"</constant> <constant cols="1" name="MAFCor" rows="12" units="%"> 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 </constant> <constant name="spkN2O" units="deg">0.0</constant> <constant cols="1" name="TauAccTable" rows="5" units="msec"> 410.0 400.0 390.0 370.0 350.0 </constant> <constant name="MAFRPM2" units="rpm">3000.0</constant> <constant name="MAFRPM1" units="rpm">1200.0</constant> <constant cols="1" name="TauClt" rows="10" units="%"> 200.0 190.0 180.0 180.0 170.0 160.0 140.0 125.0 110.0 100.0 </constant> <constant cols="1" name="crankPWTable" rows="10" units="msec"> 11.0 10.2 9.4 8.6 7.8 7.0 6.2 5.4 4.2 3.0 </constant> <constant cols="1" name="XTrpms" rows="5" units="rpm"> 600.0 1000.0 2000.0 3000.0 6000.0 </constant> <constant name="xTauOption">"Off"</constant> <constant cols="1" name="ipada" rows="48"> 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant cols="12" name="advanceTable" rows="12" units="deg"> 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 36.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 30.1 30.1 30.1 30.1 30.1 30.1 30.1 30.1 24.1 35.0 35.0 35.0 30.1 30.1 30.1 30.1 30.1 30.1 30.1 30.1 22.0 22.0 22.0 24.1 30.1 30.1 30.1 30.1 30.1 30.1 30.1 30.1 19.9 19.9 19.9 24.1 30.1 30.1 30.1 30.1 30.1 30.1 30.1 30.1 19.9 19.9 19.9 24.1 30.1 30.1 30.1 28.0 28.0 28.0 28.0 28.0 19.9 19.9 19.9 23.0 28.0 28.0 28.0 26.0 26.0 26.0 26.0 26.0 19.9 19.9 19.9 20.0 23.0 23.0 23.0 23.0 23.0 23.0 23.0 23.0 19.9 19.9 19.9 19.9 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 </constant> <constant cols="1" name="XAccTable" rows="5" units="%"> 30.0 30.0 30.0 30.0 30.0 </constant> <constant cols="1" name="primePWTable" rows="10" units="msec"> 6.0 5.6 5.2 4.8 4.4 4.0 3.6 3.2 2.6 2.0 </constant> <constant name="AMCNBurns" units="burns">0.0</constant> <constant name="MatRtdRPMHi" units="rpm">1500.0</constant> <constant cols="1" name="aseCntTable" rows="10" units="cycles"> 350.0 330.0 310.0 290.0 270.0 250.0 230.0 210.0 180.0 150.0 </constant> <constant cols="12" name="veTable1" rows="12" units="%"> 40.0 40.0 40.0 40.0 40.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 40.0 50.0 60.0 60.0 60.0 60.0 60.0 60.0 60.0 60.0 60.0 60.0 32.0 47.0 60.0 60.0 60.0 60.0 55.0 50.0 60.0 60.0 60.0 60.0 32.0 50.0 80.0 80.0 80.0 80.0 70.0 70.0 95.0 95.0 95.0 95.0 34.0 60.0 90.0 105.0 100.0 80.0 70.0 70.0 103.0 103.0 103.0 103.0 34.0 70.0 90.0 105.0 100.0 88.0 75.0 75.0 103.0 103.0 103.0 103.0 34.0 80.0 100.0 115.0 100.0 93.0 85.0 85.0 109.0 109.0 100.0 100.0 50.0 90.0 105.0 122.0 105.0 95.0 95.0 95.0 115.0 115.0 110.0 110.0 60.0 100.0 107.0 125.0 105.0 98.0 100.0 100.0 115.0 115.0 120.0 120.0 70.0 105.0 105.0 125.0 107.0 100.0 105.0 105.0 115.0 115.0 120.0 120.0 80.0 105.0 110.0 125.0 112.0 103.0 110.0 115.0 115.0 115.0 120.0 120.0 80.0 105.0 110.0 125.0 122.0 105.0 110.0 125.0 125.0 120.0 120.0 120.0 </constant> <constant cols="12" name="veTable2" rows="12" units="%"> 26.0 26.0 29.0 34.0 40.0 46.0 50.0 55.0 58.0 61.0 61.0 60.0 29.0 29.0 32.0 38.0 46.0 53.0 56.0 60.0 63.0 66.0 65.0 62.0 38.0 37.0 39.0 44.0 53.0 61.0 65.0 67.0 69.0 73.0 71.0 66.0 43.0 42.0 43.0 45.0 54.0 63.0 66.0 69.0 71.0 75.0 73.0 67.0 48.0 46.0 48.0 50.0 58.0 65.0 69.0 71.0 73.0 77.0 75.0 69.0 52.0 51.0 52.0 55.0 62.0 67.0 71.0 73.0 75.0 79.0 77.0 71.0 57.0 59.0 61.0 65.0 69.0 72.0 76.0 78.0 81.0 85.0 85.0 80.0 61.0 62.0 65.0 69.0 72.0 75.0 79.0 82.0 85.0 89.0 88.0 84.0 65.0 66.0 69.0 73.0 76.0 78.0 82.0 86.0 90.0 93.0 92.0 88.0 68.0 70.0 73.0 78.0 81.0 83.0 86.0 90.0 94.0 98.0 97.0 93.0 72.0 77.0 82.0 87.0 90.0 93.0 95.0 100.0 105.0 109.0 108.0 103.0 74.0 81.0 86.0 91.0 95.0 97.0 100.0 105.0 111.0 114.0 113.0 108.0 </constant> <constant name="MAFDir">"Use Above"</constant> <constant cols="1" name="baroCorrVals" rows="6" units="kPa"> 80.0 90.0 100.0 105.0 110.0 120.0 </constant> <constant cols="1" name="baroCorrDelta" rows="6" units="%"> 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant cols="1" name="matCorrTemps" rows="6" units="°F"> 40.0 60.0 100.0 130.0 160.0 180.0 </constant> <constant cols="1" name="XDecTable" rows="5" units="%"> 20.0 20.0 20.0 20.0 20.0 </constant> <constant name="MatRtdRPMLo" units="rpm">800.0</constant> <constant cols="1" name="XClt" rows="10" units="%"> 160.0 150.0 140.0 130.0 125.0 120.0 115.0 110.0 105.0 100.0 </constant> <constant cols="1" name="matRetard" rows="6" units="deg"> 0.0 0.0 2.0 4.0 6.0 8.0 </constant> <constant cols="1" name="asePctTable" rows="10" units="%"> 45.0 43.0 41.0 39.0 37.0 35.0 33.0 31.0 28.0 25.0 </constant> <constant cols="1" name="TauDecTable" rows="5" units="msec"> 510.0 500.0 490.0 470.0 450.0 </constant> <constant cols="1" name="matTemps" rows="6" units="°F"> 160.0 180.0 200.0 220.0 240.0 260.0 </constant> <constant cols="1" name="MAFFlow" rows="12" units="gram/sec"> 1.0 20.0 40.0 60.0 80.0 100.0 120.0 140.0 160.0 180.0 200.0 250.0 </constant> </page> <settings Comment="These setting are only used if this msq is opened without a project."> <setting name="X_TAU_VISIBLE" value="X_TAU_VISIBLE"/> <setting name="NARROW_BAND_EGO" value="NARROW_BAND_EGO"/> <setting name="AFR" value="AFR"/> <setting name="FAHRENHEIT" value="FAHRENHEIT"/> </settings> <userComments Comment="These are user comments that can be related to a particular setting or dialog."/> </msq> Edited July 23, 2011 by J240ZTurbo Quote Link to comment Share on other sites More sharing options...
mobythevan Posted July 25, 2011 Share Posted July 25, 2011 Getting rpm should be the first priority, don't worry about messing with spark until you can see a cranking rpm in megatune/tuner studio. OK, the pictures you took of the board are pretty good so I can see that you have tachselect jumperd to optoin. XG1 and XG2 are jumpered together. Optoout is jumperd to tsel. That all looks good to me for using an 83 turbo dizzy. I would put jumpers in place of both diodes D1 and D2. Do you have the dizzy wired like this picture with the pullup resistor to 12volts? If so you should see rpm when cranking, so doublecheck that your wiring matches this AND that you have 12volts to the dizzy/pullup resistor/megasquirt when you are cranking. Quote Link to comment Share on other sites More sharing options...
J240ZTurbo Posted July 25, 2011 Author Share Posted July 25, 2011 Hi, looking at this set up, I got the ms2 with no relay board. I just bought a brand new HEI unit, you got pmd. Quote Link to comment Share on other sites More sharing options...
S130Z Posted July 26, 2011 Share Posted July 26, 2011 I had a similar problem with mine. Ended up being a bad wiring connection at the spot where you wire the MS harness into the stock turbo distributor harness. Not sure if you used that, but if so, double check all your wires. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted July 26, 2011 Share Posted July 26, 2011 Its Ok if you don't have a relay board. In that case you should have the GB wire from the dizzy tied to pin 24 of the DB37. Pin 24 is the tach input. Also, the GB wire should have the pullup resistor to 12 volts. If you have it connected like this and you jumper D1 and D2 you should get a cranking RPM in tuner studio(or megatune). Like I said before make sure the 12 volts that powers megasquirt/dizzy/pullup resistor is on during cranking and during running. Quote Link to comment Share on other sites More sharing options...
J240ZTurbo Posted August 9, 2011 Author Share Posted August 9, 2011 guys , I finally got spark. I was not getting any power after the start on the ignition, so I re-route my wires. I feel the car now wants to start but it backfires like crazy any ideas? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted August 9, 2011 Share Posted August 9, 2011 Good progress. Now you really need to put a timing light on the engine and see where the spark is during cranking. Quote Link to comment Share on other sites More sharing options...
J240ZTurbo Posted August 10, 2011 Author Share Posted August 10, 2011 guys I finally got spark, but my car won't start it back fires a little and then nothing at all. I did noticed on my lap top screen that even do I now got spark I still dont show any RPM movement in tuner studios on my screen, any ideas what could be wrong now??? thanks, Juan. Quote Link to comment Share on other sites More sharing options...
akeboshi Posted December 18, 2011 Share Posted December 18, 2011 I was just curious if you got your issues sorted out? Marcus Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted December 18, 2011 Share Posted December 18, 2011 That trigger offset should be close to 60, if you haven't fixed that already. Quote Link to comment Share on other sites More sharing options...
