abc_was_here Posted August 15, 2011 Share Posted August 15, 2011 (edited) Okay well short story, Swapped in a L28ET. Got the car running decent, started every time and pulled pretty good. Now sometimes when I go to start the car after its been sitting a while it wont start at all. Pull the wire ground it, no spark. At the same time the tach does not jump. So I pretty much think its the CAS. Anyway I go on ahead and replace it with another one that I had car fired right up and gave me no problems. Drove it like that for three days and no problems. I go camping for the weekend then come back and the same problems persist now. Car wont start or I have to fiddle with things to get it to start. I figured I had fixed the problem with the CAS. It did do this too, tach would all of a sudden start shooting around as I was driving. or the car would just die as the clutch is still out in gear no tach. I figures theres only three real problem areas.. CAS Ignitor ECU I have replaced the CAS and ignitor already from spare parts I had. Although if anyone else has any other ideas or similar experiences to share that would be great. Thanks Edited August 15, 2011 by abc_was_here Quote Link to comment Share on other sites More sharing options...
aarang Posted August 15, 2011 Share Posted August 15, 2011 Mine had a similar problem where it would randomly die, but mostly when it got hot. I changed the distributor with a spare I had and that fixed it for a while, but the problem returned. After much troubleshooting with a multi meter, it turns out the short harness from the distributor to the main engine harness was bad. Changed that and the issue went away. Hope that helps some. Quote Link to comment Share on other sites More sharing options...
