proxlamus© Posted August 31, 2011 Share Posted August 31, 2011 Already.. just did some homework.. now the price breakdown.. does this sound about right?! $2,500 front sump Aristo 2JZGTE $400 rear sump oil pan + gaskets $350 1JZ bell housing to run the R154 5-speed $575 ACT clutch kit for 7MGTE/R154 $350 1JZ Flywheel $500 R154 transmission $500 Megasquirt (MSII 3.57 and harness) $350 engine cradle from Beta Motorsports ____________________________ $5,525 not including upgrading the fuel injectors, possible single turbo upgrade with manifold, intake plenum, NO intercooler and piping, fuel pump, hoses, Drive Shaft... etc etc. Does that sound about right?! Quote Link to comment Share on other sites More sharing options...
pat1 Posted August 31, 2011 Share Posted August 31, 2011 (edited) looks right. Don't forget the small stuff. You could save some money and build your own mounts. Mine cost me less than 40.00 to make. I've seen the rear sump pans go for 250.00 and the flywheels go for 50.00 all day long unless you want to use a over priced alunimum flywheel. you can get the clutch kits for alot less than 575.00 Edited August 31, 2011 by pat1 Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted August 31, 2011 Author Share Posted August 31, 2011 Yeh I'm keeping the prices on the higher end, for new components just to get an idea.. I can source down parts for fairly cheap with lots of searching. Jeesh, I can see why people end up spending close to 10k on a good motor swap, whether its a LSx, xJZGTE, RB2xDET(t) Quote Link to comment Share on other sites More sharing options...
pat1 Posted August 31, 2011 Share Posted August 31, 2011 I would have to add it all up but I know I don't have anywhere near 5k in my 1jzgte. Check out my build thread. Search for the parts, I found my parts cheap. Quote Link to comment Share on other sites More sharing options...
piston Posted September 1, 2011 Share Posted September 1, 2011 I think I'm in the 5k ball park on my 2jz na-t. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 2, 2011 Author Share Posted September 2, 2011 This sounds crazy... but I was looking into a 2JZ thinking the total cost of the build would be cheaper then a RB26 swap, but after sitting down and adding up misc. parts, the swaps are almost the same price!! Literally within just a few hundred dollars!! Crazy! Quote Link to comment Share on other sites More sharing options...
pat1 Posted September 2, 2011 Share Posted September 2, 2011 You are correct. I was pondering the idea of a rb26 swap and decided on the 1jz because the parts being available and the cost of upgrading the 1jz. Plus not alot of people have the 1jz swap in my area. You can get 500 rwhp out of a 1jz with a bone stock bottom end, a set of cams, injectors and a nice size turbo. And you can use the stock ecu with a piggy back. 1jz engine swap. 2300.00 Injectors 550 out of a usdm 2jzgte 200.00 Nice turbo. I'm using a pt-61 that I got new for 500.00 Hks 274,264 cams 500.00 used Apexi neo 180.00 3680.00 plus the little stuff and get a stupid fast Z. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted September 2, 2011 Share Posted September 2, 2011 Here is great deal on 2jzge-t: http://www.supraforums.com/forum/showthread.php?645570-2jz-ge-w-bw-s372-BL-2.5mm-HG-sp-quick-spool-valve-ebay-mani-ebay-intake-mani Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 3, 2011 Author Share Posted September 3, 2011 Ivan, looks like I need to register to view the thread.. tell me more! Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted September 3, 2011 Share Posted September 3, 2011 On 9/3/2011 at 1:21 AM, proxlamus© said: Ivan, looks like I need to register to view the thread.. tell me more! If you are looking into 2j then its in your best interest to register on SF. If you register you will get access to members build threads, drag racing forum, dyno # forum and so on. Quote Link to comment Share on other sites More sharing options...
joa_taste Posted September 23, 2011 Share Posted September 23, 2011 Just to add in my .02 cents you could buy a 2jzge from a sc300 for like 200-600 bucks, and boost that...same bottom end as a 2jzgte (I sold my mk3 supra for a lexus sc300 to do just that, then i sold the lexus for more money for the z) Oh and r154's you sometimes can get them for a little less than 500 if your lucky and find at junkyard. but mostly those things are expensive as hell, people tend to sell them for wayyyy more than they are worth Quote Link to comment Share on other sites More sharing options...
arjun Posted September 26, 2011 Share Posted September 26, 2011 I'm not 100% sure but I think Beta motorsports doesn't make the crossmember anymore. If that turns out to be the case and you can't fabricate your own just PM me. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted September 26, 2011 Share Posted September 26, 2011 On 8/31/2011 at 1:43 AM, proxlamus© said: Already.. just did some homework.. now the price breakdown.. does this sound about right?! $2,500 front sump Aristo 2JZGTE $400 rear sump oil pan + gaskets $350 1JZ bell housing to run the R154 5-speed $575 ACT clutch kit for 7MGTE/R154 $350 1JZ Flywheel $500 R154 transmission $500 Megasquirt (MSII 3.57 and harness) $350 engine cradle from Beta Motorsports ____________________________ $5,525 not including upgrading the fuel injectors, possible single turbo upgrade with manifold, intake plenum, NO intercooler and piping, fuel pump, hoses, Drive Shaft... etc etc. Does that sound about right?! Maybe it's different in colorado but I can't find an R154 for under $700 locally. Also I thought the bell housings were >$400 plus shipping from most places. Same with the oil pan, last time I priced one out it was a lot more. I heard a good place to get them is a Celica Supra site as they need a front sump setup, and most will trade you for a front sump. Why not just get a mid sump engine from the start? Quote Link to comment Share on other sites More sharing options...
