Cam question
tyler031734
I have a stock L28ET, will be 370cc injectors and msII
running a mandrel down pipe and IC.
Im concerned about valve overlap on a turbo engine possibly a bad thing, among other things.
Is the cam possibly to big for my nice DD 240z?
I think it maybe a good choice being as the operating range of the cam is low RPMs.
I have little knowledge on cam dynamics and as for why this cam? Because its sitting on the shelf.
any help would be appreciated
Edited by tyler031734
that is not a turbo cam. has narrow 110 lsa and more exhaust than intake duration.
the amount of overlap a turbo engine can take depends on the restriction in the turbine. Small restrictive, low rpm boosting turbines can't handle any overlap. A big, high flow, higher rpm boosting turbine can handle more over lap. at what rpm does you engine start to boost and make peak boost?
I found the stock non-turbo cam works well as a "performance cam upgrade" for a low rpm boosting turbo setup.
The stock non-turbo cam has 8 more degrees of intake duration, as compared to the stock turbo cam, which is good for about 1000 rpm more of power band.
use a cam out of a 75 to 80 L28 engine with a N47 head. These are the biggest internally oiled cams.
I started with a stock turbo cam. It was ok for a stock turbo but ran out of rpms too early. So I put in a msa turbo stage 1 cam. The valve train was a little noisy for my taste and the power band a little too high. So after a few years of using the msa cam, I switched over to a stock non-turbo cam and I really like it.
I have one A cam from the N47 I have but its toasted!
As for getting a custom cam, That sounds like a shot in the dark to me.
I have no idea the amount of back pressure I have is and im always screwing with stuff.
I may see if I can find an A cam, without having to spend to much cash for it.
